SONY ct150 - JVC BC1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-06-2012, 08:56 AM - Thread Starter
bobbee25's Avatar
I picked up the JVC BC1, but the dialog is muddy with some shows, I need to turn up the tv speakers to offset the issue. So we don't use it very often.
I just realized that the sub woofer has to be a powered type. Before I spend $100 for a subwoofer, I am wondering if I would be better off with the Sony. Will the center speaker control fix the dialog issue and it comes with a sub woofer ?
bobbee25 is offline
post #2 of 2 Old 05-06-2012, 09:59 AM
Peter McM's Avatar
I love my CT-150. Center speaker turned up to 4 or 5 will nicely balance the smooth oomph from the sub.
Peter McM is offline
Reply Soundbars
Sony Ht Ct150 Virtual 5 1 Channel Sound Bar And Subwoofer Set Accessory Kit
