YSP-5100 help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-09-2012, 09:16 PM - Thread Starter
davestercrombie's Avatar
Hello all. I was wondering if anyone out there would have some advice for me.
I bought a YSP-5100 last week. This week I mounted it to the wall using the Yamaha wall mount and connected it all up.
When I go to do the auto setup for the sound it keeps giving me an error. It says
"error e-6 the volume level is lower than expected check mic position/connection and retry"
I have checked the mic a half dozen times and changed the location a bunch.
I was wondering if anyone on here had any insight into some possible solutions.
David
davestercrombie is offline
Reply Soundbars
Yamaha Ysp 5100bl Digital Sound Projector Black
