Sound bar recommendation - AVS Forum | Home Theater Discussions And Reviews
Old 06-19-2012, 10:20 AM - Thread Starter
french_guy's Avatar
Quoted: 14 Post(s)
Hello
I used to have a Panasoni cSA-XR55 receiver, with a Jamo S413 5.1 system......(and by the way, i was only using the front speakers, central and sub-woofer, i never installed the rear speakers)
But this systemis sol now
What sound bar would you recommend in the $300 range? I know I won't have the same sound than a real 5.1, but since I was used to my system without the rear speakers, I guess I can live with a sound bar...(I want to have a clean installation, no mess with too much cables)
It seems that the Sony HTC150 is a solid choice, but what about other models?
french_guy is offline
