Lifestyle 135 or....... - AVS Forum | Home Theater Discussions And Reviews
Old 07-11-2012, 06:26 PM - Thread Starter
HiFox23's Avatar
Ok, before the Bose hate starts raining in I'm looking for some honest advice or alternatives. I've searched these forums and have looked for other options but I can't seem to find a decent alternative. I'm not opposed to piecing together a sound bar unit but I don't know where to start. I need a receiver, 4 HDMI Inputs, 3D Support and subwoofer. I understand the Bose unit is expensive, but it meets all my criteria in a one-stop solution. I've looked at the Bowers and Wilkins Panorama, the Harmon Kardon HB 30 and a few of the Yamaha units but they lack the connectivity I desire. I can buy a HDMI Switch for my TV to hook 4 devices up by then I'm still short on Optical or Coax audio hookups on the sound bar units. Thanks in advance for the help....
HiFox23 is offline
Old 07-28-2012, 09:28 PM
Chicagorep's Avatar
I keep saying this, if you find a better performing sound bar than the Bose LS 135 then buy it but you won't. Bose set one hell of a benchmark with their two soundbars.
Chicagorep is offline
Old 08-09-2012, 09:16 AM
Ex_Brit's Avatar
I'm a Bose Lifestyle 135 owner and am very satisfied with it. I know the price is crazy, but as you point out, it's a one-stop solution. In my case as all inputs are in use I actually had to use a 3D-ready auto-switching 3-way HDMI connector to connect 2 Blu-ray players to one input (space for one more there if needed) and an audio input selector box to connect my turntable (via pre-amp) and my tape deck to one other input. With the provided iPod/Pad (with adapter)/Phone connector also linked up plus a tentative future Boselink connection to give audio out to my computer, it's a fully-loaded setup and have often wondered how my local power station copes, just kidding.
Very few, if any, soundbars offer all the connectivity that this unit offers.
Note that a firmware update to the unit is required to give it 3D video capability, at least when I got mine I had to do that. It's an easy operation.
The sound is spectacular and you can tailor it to your surroundings using the provided AdaptiQ headphones if you wish.
There's a lot packed into a very compact unit and it doesn't generate a lot of heat I've noticed, which is a good thing.
My only beef with it would be no regular audio-out sockets (other than speakers of course), you have to use Boselink as stated earlier, which means optional extras, but there is a headphone jack on the front of the unit.
By the way it also pulls in FM/AM very well using the provided antennae.
Peter
Toronto, Canada
Ex_Brit is offline
Harman Kardon Sb 30 5 1 Soundbar And Wireless Subwoofer , Bose Lifestyle 135 Series Ii Home Entertainment System
