Help with Connecting Panasonic SC-HTB550 Sound bar to Logitech Harmony One - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-15-2012, 09:35 PM - Thread Starter
Ragamuffin143's Avatar
Can anyone offer some advice about getting your Panasonic SC-HTB550 to work with your Logitech Harmony One remote? I've got the HTB550 connected to my Panasonic TC-L47E50 (HDMI ARC) and a Comcast cable box all with HDMI. The TV's speakers are off, and the Viera link seems to be working okay (sound bar turns on and off, and I can see the sound bar volume level appear on the TV). However, the input selector on the HTB550 does not change when I choose "Watch TV" or "Watch DVD" on my Logitech. I also can't control the Dialog level or the sub-woofer level.
Another frustration is that when I choose "TV" on the HTB550's input selector, I get video, but not sound. I have to choose "Auxiliary 1" for video and sound. I'm okay with it, but my wife always forgets and you wouldn't believe the number of calls I get at work about it.
Ragamuffin143 is offline
post #2 of 2 Old 01-26-2015, 02:01 PM
meat-ball's Avatar
Hey I realize this post is ancient, but was curious if you ever figured out how to get the inputs switched automatically with the harmony? I'm pretty sure this isnt going to work with viera link on (harmony requires cec to be turned off otherwise it can't gauge what input the tv is on).
meat-ball is offline
Reply Soundbars
Panasonic Sc Htb550 2 1 Channel 240 Watt Multi Positional Full Hd 3d Audio System With Wireless Musi , Panasonic Viera Tc L47e50 47 Inch 1080p Full Hd Ips Led Lcd Tv
