help with required cables when hooking up a yamaha subwoofer to the vizio soundbar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-26-2012, 09:03 AM - Thread Starter
loulou1965's Avatar
Hello; hoping someone can help;
I am trying to hook up my yamaha subwoofer to my vizio sound bar, not having much luck, to the point of really thinking about returning the sound bar;
I purchased a subwoofer cable, does not fit securley into the sound bar port, was told by vizio to use a single rca cable, but then was told by tech store, that if the subwoofer has 2 ports you use 2 ports,
any help would be great, thanks
loulou1965 is offline
post #2 of 2 Old 07-26-2012, 01:02 PM
drfreeman60's Avatar
Liked: 52
You don't specify which model soundbar and which model sub-woofer you have, but the following should work for any.
Single RCA male to male cable of the appropriate link. If your cable run requires a length longer than 15', you may want to look for a heavy duty cable.
If your sub-woofer has two RCA inputs and does not have a switch to sum L+R channels you will need a RCA female single input to dual male output.
All available from Radio Shack o any of the on-line cable companies for less than $ 5.00.
David Freeman
drfreeman60 is offline
Reply Soundbars
