Def Tech SSA-42 hookup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-08-2012, 03:37 PM - Thread Starter
Scooby06's Avatar
Hooking up the sound bar to a Denon 1909.It doesn't have the speaker wire,so I am trying to decide as to what gauge of wire to use. I have been told everything from 14-18 gauge. The wire run will be less than 10ft. From what I have read,22ga would actually work.Polk makes a cable that is 18gauge that is all one flat piece.That would be good to keep the back a little neater if that would work. What do you guys think? I was also thinking about getting a roll and cutting 5 lengths,but I still need to know what gauge.Thanks
Scooby06 is offline
post #2 of 3 Old 08-08-2012, 04:33 PM
Possumgirl's Avatar
Liked: 58
For runs that short, 16-18 AWG would be fine. Even the 22 should be okay if you prefer thinner wire, but if it were me I'd stick with the 16-18.
Possumgirl is offline
post #3 of 3 Old 08-08-2012, 04:47 PM - Thread Starter
Scooby06's Avatar
Thank you.
Scooby06 is offline
Reply Soundbars
Denon Avr 1909 7 1 Channel Multizone Home Theater Receiver
