Samsung HW-e450 and Samsung smart hub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-13-2012, 08:07 PM - Thread Starter
birixiote's Avatar
Hi guys,
I have the hw-e450 soundbar and samsung un55es7100 tv. For some reason I can't get any sound out of the TV when in the smart hub mode. I get any sound out of any of the apps, e.g. Netflix, YouTube, etc. I have tried connecting via both HDMI cable as well as Audio cable. Any idea what I am doing wrong?
I havent tried hooking up the soundbar with my cable box or my dvd player but bluetooth does work.
Any help will be appreciated.
Thanks!!
birixiote is offline
post #2 of 4 Old 08-14-2012, 08:55 AM
Possumgirl's Avatar
Liked: 58
Originally Posted by birixiote View Post
Hi guys,
Thanks!!
Can't tell just how much debugging you've done. With the HDMI connection between soundbar and TV, be sure you're using the HDMI(ARC) port on the TV. Be sure you have Anynet+ enabled on BOTH the TV and the soundbar. Change audio settings on the TV to direct the audio out to "external" and turn off the TV speakers. Also, try connecting your cable box and/or DVD player to the TV and see if you are getting audio to the soundbar from those devices.
If you need to try using the optical cable, turn Anynet+ OFF on both TV and soundbar.
Let us know if these suggestions helped.
Possumgirl is offline
post #3 of 4 Old 08-14-2012, 09:04 AM - Thread Starter
birixiote's Avatar
Thanks Possumgirl. I am using the HDMI(arc) port on the TV. But I didnt try the Anynet+ option. I'll give that a shot. I do have my cable box hooked up to the TV via HDMI but i dont get any audio from that to the sound bar through ARC.
I will let you know if anynet+ and turning off audio works....
post #4 of 4 Old 08-14-2013, 10:57 PM
Solomon Lee's Avatar
hey birixiote, did you find a fix for this? i'm having the same issue.
Solomon Lee is offline
Reply Soundbars
Samsung Hw E450 Wireless Airtrack Soundbar
