Who is using a Soundbar with a Projector setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-10-2012, 07:50 AM - Thread Starter
Wytchone's Avatar
Quoted: 38 Post(s)
Liked: 53
Thinking of going with a sound bar vs a traditional 5.1 setup to be used with my projector.
Im hoping someone else is doing this now and can tell if if they love, like or hate it. What brand you are using, what brand do you think is the best. Its my media room so on this part i will have a budget of about $450. As it stands im thinking about the Yamaha YHT-S400BL but that was found on my first search. I am open to other suggestions.
My room is square 11.5' x 22' but I will be sitting about 8 or 9 feet max back from the screen. I envison the sound bar to be under my screen right at ear level.
Wytchone is offline
post #2 of 11 Old 09-13-2012, 11:44 PM
davyo's Avatar
I have used soundbars with my projectors and they have worked great,,, just get a bar that has HDMI inputs and you will be fine,,,, I always used the Sony CT soundbars.
Cheers
Davyo
davyo is offline
post #3 of 11 Old 09-14-2012, 12:23 AM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
I don't use one with my projector, but why do you want to? I would rather use a pair of bookshelf speakers than a soundbar.
Jim McC is offline
post #4 of 11 Old 09-14-2012, 05:16 AM - Thread Starter
Wytchone's Avatar
Quoted: 38 Post(s)
Liked: 53
Cheers
Davyo
Thanks Davyo. I will be using a Sony soundbar for the first time. I hope a wireless subwoofer will be nice still being wireless I can move it quickly smile.gif
See my sig Jim. I flooded. Since it(the flood) has never happend before and might happen again. I want a way to remove items out of my room quickly.The room is mostly made of glass so limted mounting options. Sound bar I can mount with no issues.
I lost all my bookshelf speakers and subwoofer. This is my attempt to make it easy to save items or I would go back to my 5.1 setup.
Wytchone is offline
post #5 of 11 Old 09-21-2012, 08:42 AM
Droid6's Avatar
HERE is a link to my sound-bar/projector setup. This setup would fit your budget if you just got the sound-bar and a receiver and left out the sub woofer. Without a sub-woofer this bar will still be bassier than the plastic sound-bars with sub-woofers that are most recommended here. You can add a sub at your leisure if you see fit.
Droid6 is offline
post #6 of 11 Old 09-21-2012, 08:20 PM - Thread Starter
Wytchone's Avatar
Quoted: 38 Post(s)
Liked: 53
The more I read about this the more I like. Wish is was HDMI for ease of movement. Still I can get it up higher then say foot of the gound easy.
I think you may have sold me on this. I did save my 7.1 receiver so I can get the base for this also.
Wytchone is offline
post #7 of 11 Old 09-21-2012, 08:29 PM
ambesolman's Avatar
Quoted: 1100 Post(s)
Liked: 921
Cheers
Davyo
I think I'd invest in some basement waterproofing if you're afraid of it happening again.
ambesolman is offline
post #8 of 11 Old 09-22-2012, 05:40 AM - Thread Starter
Wytchone's Avatar
Quoted: 38 Post(s)
Liked: 53
Best I can do is do lay tile. Issue is till we get the Corp of Enginners report, we have no idea if it will happen again. It just has never happend before.
Wytchone is offline
post #9 of 11 Old 09-22-2012, 09:17 AM
zoey67's Avatar
Quoted: 180 Post(s)
Liked: 97
I have a YSP 5100 with a velodyne cht-10 and Epson 1080UB/100" electric. Very happy with it, I've upgraded from ysp3000 and ysp1100 and they were also excellent. Pls don't listen to that advise of using bookshelf, that makes no sense unless you have at least 5 but it's not worth the hassle. Yamaha sound bars are awesome, I don't know how they do it but every single person who has been to my home tell me they can't believe the sound is coming from 1 speaker. And don't worry about output, it can play very loud and clean. I've had very good 5.1 systems with a denon 3805 with mid level and high level Kef speakers and Hsu subs VTF 2.3 and ULS 15 and what I have now is no compromise to what I've in the past NO sir ree.
The 5100 is very long so it I had to put it on top of my Kathy Ireland ent center which has 31" opening with a cover that can house most sound bars so I used that when I had the 1100 and 3000 and people could not see the speaker so they were like where is the sound coming from. Oh, and my room is 23x13x8 with openings to a kitchen and dining room to the left that you can't see.
zoey67 is offline
post #10 of 11 Old 09-24-2012, 05:19 AM - Thread Starter
Wytchone's Avatar
Quoted: 38 Post(s)
Liked: 53
Thanks Zoey! You are one of the few people who have said what amazing sound you can get out of a bar. Of course the one you list is pricey but it does give me hope smile.gif
Wytchone is offline
post #11 of 11 Old 12-30-2016, 12:18 AM
Liked: 0
Visuals going hazy when I connect the Aux Cable.
Hi, I have a Hitachi 3LCD projector which I use with a hdmi convertor cable to project from my Laptop.
Before connecting the Aux cable to my samsung Sound Bar the screen is perfect, as i connect the cable the visuals go hazy and scratchy. What can i do to prevent the hazy screen.
Husain K Virpurwala is offline
Reply Soundbars
