Hello all - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-18-2012, 04:41 PM - Thread Starter
Ryan1986's Avatar
As you can see from my username, my names Ryan. Just recently starting getting into the home audio thing. I recently bought a tv and wanted to upgrade my tvs speakerso I decided i wanted a soundbar. At first i assumed its a simple setup buy read on other threads about hooking up this to this , then that to that so i decided to make my own thread for help
I have a 55 inch Sanyo DP55411
Ps3( used for movies and obviously gaming)
Comcast dvr box both using hdmi cables
Is there a certain kind of soundbar needed to work woth my ps3( since its mainly used for movies)?
Ryan1986 is offline
post #2 of 7 Old 09-18-2012, 04:51 PM
Possumgirl's Avatar
Liked: 58
Ryan, I just responded to your PM.
Possumgirl is offline
post #3 of 7 Old 09-18-2012, 05:15 PM - Thread Starter
Ryan1986's Avatar
Thank you, but i'm only allowed 2 private messages so i'll pick up here. What do you mean by matching tv input/output?
Ryan1986 is offline
post #4 of 7 Old 09-18-2012, 05:16 PM - Thread Starter
Ryan1986's Avatar
Ryan1986 is offline
post #5 of 7 Old 09-18-2012, 05:16 PM - Thread Starter
Ryan1986's Avatar
Ryan1986 is offline
post #6 of 7 Old 09-18-2012, 07:18 PM
Possumgirl's Avatar
Liked: 58
An example of what I meant is if a TV only has optical audio out, you would want a soundbar that has optical audio input (assuming you need to send audio out from your TV).
People may be able to suggest some soundbars for you to look at if you post your room size, whether you have walls for sound reflection, and whether you mostly want improved dialog, a surround effect, etc.
post #7 of 7 Old 09-18-2012, 08:01 PM - Thread Starter
Ryan1986's Avatar
I'm moving into my apt next week. I don't know the exact dimensions off the top of my head
But this setup will be in my room not in the living room. So obviously in a smaller area. Overall, i Wanna imrpove the dialog along with a tad more bass.
Ryan1986 is offline
Reply Soundbars
