Passive or Active Soundbar? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-22-2012, 03:06 PM - Thread Starter
IowaDad's Avatar
Hello all!
I'm currently looking for a replacement for my exising 5.1 speaker system. I purchased a new reciver just under a year ago (Denon AVR-1712) so ideally I would like to keep using that and my existing Sub. My wife does not want any satelite speakers and/or speaker wires run in the room. I'm new to the Soundbar market and I have been looking over past posts trying to find a good solution. We don't listen to much music, mostly TV and Blu-Rays (delivered via my HTPC). I just purchased a new Panasonic TC-P55GT50 and my thinking is that a soundbar would be sitting below the TV.
I'm currently looking at the following:
Atlantic Technology FS-7.1
Definitive Technology Mythos Solo Surround Array SSA-50
Definitive Technology Mythos Solo Surround Array SSA-42 (I don't think having an 8" smaller bar would be a big deal)
BIC FH56-BAR
So my questions:
Is it worth using my existing receiver and sub and go with one of these passive solutions (or is there another brand/model that I haven't seen yet)?
Should I scrap the receiver and sub and go with an active solution (Yamaha ysp-2200bl) and plug my HTPC into the sound bar and just output video to the Panasonic?
Thanks in advance!!
IowaDad is offline
post #2 of 3 Old 09-22-2012, 08:33 PM
BobL's Avatar
Liked: 56
It partly depends on your room. We have installed the AT and Yamaha bars. The Yamaha will give a better surround effect if you don't have side or back walls. The AT sounds better but really benefits from side walls and preferably a back wall as well to get a good surround effect. I haven't used the Bic or Deftech. I'd probably go the AT route just for the better sound.
BobL is offline
post #3 of 3 Old 09-22-2012, 08:59 PM - Thread Starter
IowaDad's Avatar
Thanks for the info. My room looks something like this:
Or somethign like that. Room is pretty much a rectangle with entryway middle of the left wall and back behind the couch. I'm really new to the soundbar market and I dont know if its worth keeping the receiver and wiring up a 5 or 7 speaker system or go with a powered soundbar system and discard the Denon.
I finally have approval to purchase something from the CEO, CFO, CIO and COO (my wife... =) ). So I need to make sure the decsion is an accurate one!
IowaDad is offline
Reply Soundbars
