Easiest way to connect record player to soundbar? - AVS Forum | Home Theater Discussions And Reviews
Old 09-22-2012, 03:43 PM - Thread Starter
rc251's Avatar
Hi everyone, I have this soundbar:
http://www.amazon.com/Yamaha-YAS-101BL-Front-Surround-System/dp/B005IVUWHW/
It has 2 optical digital and 1 coaxial digital input.
I also have this record player:
http://www.amazon.com/Technica-AT-LP60-Automatic-Driven-Turntable/dp/B002GYTPAE/
It has dual RCA outputs, along with cables to convert that to male or female miniplug.
Is there an easy way I can connect the turntable to the soundar directly? What kind of accessory would I need? Thanks!
rc251 is offline
Old 09-22-2012, 06:18 PM
Possumgirl's Avatar
Liked: 58
Since the turntable has a pre-amp, one of these adapters should do the trick.
Possumgirl is offline
