42" LG Plasma TV + Apple Airport Express + Bose Wave System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-02-2012, 12:01 PM - Thread Starter
jaydriguez's Avatar
So my "soundbar" would be the Bose Wave System, but the tv only has toslink optical out, the Airport Express (which I use to stream music wirelessly) uses 3.5mm out, and the Bose system only has 3.5mm in.
I would really love to use the Bose system for both the TV and the Airport Express. Can anyone solve this? Is it even possible?
jaydriguez is offline
post #2 of 5 Old 11-02-2012, 12:48 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
If I remember correctly, the Bose Wave Radio only has one external 3.5mm input so if you want to use multiple sources you will have to use some sort of switching device or manually change the input cable from each device when you want to use it.
You didn't mention if you were using a satellite, cable box, antenna, DVD, etc. If you can be more specific I can help you.
Dropkick Murphy is offline
post #3 of 5 Old 11-02-2012, 12:59 PM - Thread Starter
jaydriguez's Avatar
Thank you so much for the response.
Any idea on what that switching device may be?
I have nothing fancy set up. It's basically just my tv, and I have an Xbox 360, a PS3, and a Mac Mini all connected to the tv via HDMI. I mostly use the ps3 for blue rays, Xbox for Netflix, and Mac Mini or anything that's not available on my other devices. My main concern is being able to produce the sound that comes from the tv AND the airport express through the Bose Wave system (and you're right, it only has one 3.5 input).
Any suggestions are welcomed!
post #4 of 5 Old 11-03-2012, 06:28 AM
Quoted: 71 Post(s)
Liked: 89
This is the easiest and most cost effective way to do what you want to do.
Buy this: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10229&cs_id=1022901&p_id=1419&seq=1&format=2
plug it into your TV.
Buy this: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=6884&seq=1&format=2
plug it into the optical cable
Buy this: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021815&p_id=5612&seq=1&format=2
plug it into the adapter
Buy this: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021802&p_id=644&seq=1&format=2
Plug one end into your Bose Wave radio and when you want TV sound manually plug it into the TV adapter, when you want music unplug from TV adapter and plug it into the Apple Express.
The manual switching part is not exactly ideal but with only one input on the radio you're kind of limited. You may be able to find some kind of 3.5mm A/B switch on that website but I'm sure it would be manual anyway.
post #5 of 5 Old 11-03-2012, 09:42 AM
Possumgirl's Avatar
Liked: 58
There are manual A/B switches, but they run at least $25 and you still have to get up and flip a switch. The above solution should work fine, but be sure your TV can be set to output PCM, or that it only outputs PCM from connected devices. The DAC will only work with PCM input.
Possumgirl is offline
Reply Soundbars
