Mounting a Vizio VSB200 to Panasonic VIERA TC-L42E3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-03-2012, 02:12 PM - Thread Starter
JT1521's Avatar
Yes I just bought the Vizio VSB200 soundbar and it is on it's way. I would like to mount it above my TV which is a Panasonic VIERA TC-L42E3. I just looked at the back of my TV and I don't see any place to use the Sewell Universal Soundbar Bracket that I am looking at on Amazon.com. Anyway know if it is possible to mount that bracket to my TV and soundbar? Thanks.
JT1521 is offline
post #2 of 2 Old 11-03-2012, 03:54 PM
Possumgirl's Avatar
Liked: 58
These universal brackets typically attach to the VESA mount holes on the back of yourTV. If your TV is on its pedestal, the holes probably have plugs in them so you might not have noticed them. I see several reviews on both Amazon and Sewell sites where people have used the brackets with Vizio soundbars and Panny TVs.
Possumgirl is offline
Reply Soundbars
Panasonic Viera Tc L42e3 42 Inch 1080p 60 Hz Led Lcd Hdtv , Vizio Vsb200 Universal Hd Sound Bar
