Question regarding multiple devices with Samsung HW-E450/ZA soundbar. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-03-2012, 01:43 PM - Thread Starter
Xarlyn's Avatar
Hello everybody. I'm trying to wrap my head around these connections, so I figured I'd come here for a little guidance. I have a Samsung HW-E450/ZA soundbar, and it's currently hooked up to my PS3 without any issues. Cox Communication has given me a pretty good deal on TV, so now I'm throwing a cable box into the mix. Do I need to get my receiver out of of the closet so that I can use my soundbar for both TV and PS3? Or is there a way to hook it up that I'm just not thinking of?
Xarlyn is offline
post #2 of 3 Old 11-03-2012, 02:59 PM
Possumgirl's Avatar
Liked: 58
I assume you have the PS3 connected directly to the soundbar and then an HDMI from soundbar to TV. The cable box will need to be connected to your TV since the soundbar only has one HDMI input. If your TV supports ARC you should be good to go. If no ARC, then run an optical cable from TV to soundbar. You'll find lots of discussion on connections in the main HW-E450 thread.
http://www.avsforum.com/t/1397976/samsung-hw-e450-soundbar
Possumgirl is offline
post #3 of 3 Old 11-03-2012, 03:16 PM - Thread Starter
Xarlyn's Avatar
My TV doesn't mention anything about ARC and the TV itself doesn't say "ARC" next to the HDMI ports. I assume Viera Link isn't the same thing as ARC. So I'm guessing I'm going to have to go with an optical cable from the TV to the soundbar. Thank you very much Possumgirl. Your input is more than appreciated.
Xarlyn is offline
Reply Soundbars
Samsung Hw E450 Wireless Airtrack Soundbar
