Budget minded..please help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-06-2012, 09:58 AM - Thread Starter
cctaylor88's Avatar
Quoted: 13 Post(s)
Hey guys...as Im sure you know many of the speakers that come with the HDTVs are poor and my TV is no exception. I really want to get decent audio quality from my TV as I watch many movies etc on it. The major problem seems to be that my TV has no traditional "audio out" outputs (the RVCA red/white I think it is)....so Im pretty sure the sound bar I choose must have an optical input (as my TV has optical out for audio)...am I correct?
I really dont want to spend over $100 as basically any sound bar will be a great improvement over my standard TV speakers...I would like any suggestions you guys may have. It seems that vizio has many cheap options in my price range...but I do notice a lot of their vizio vsb200 (the entry level bar) have a lot of refurbs on multiple websites, so is vizio not the best brand to go for?
Also..
Is a subwoofer really worth the extra $$? It would be cool to have a wireless subwoofer with my soundbar and place it under my bed no?
I will spend a bit over my price range if its worth the price..but like I said anything is better than what I have now. My TV is 42inch
Thanks in advance!
CPU: Intel i7 6700k
GPU: EVGA 1080 FTW
Motherboard: Gigabyte G1 Gaming 7
Cooler: Corsair Hydro Series H115i
Case: NZXT H440 Red/Black
Monitor: LG 34" UC88-B
cctaylor88 is offline
Reply Soundbars
