Sound bar for an apartment reccomendations needed. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-09-2012, 11:14 AM - Thread Starter
resnic's Avatar
I am getting a sound bar for my girlfriend for christmas and need some help since I know jack about home audio really. We dont need a lot, just something to help improve the sound quality and give it a more room filling quality.
She has a lcd vizio tv.
Would like something that when you adjust the volume of the tv it adjusts the soundbar also. So if we mute or turn volume up/down on the tv the soundbar will adjust also. If this is possible it would be great.
Would like something that is more about sound quality for like mid/hi without sounding muddy. Sheer volume and big bass arent what we need since its in an apartment.
Dont have a lot to spend, maybe 100-125.
Link me the item you would reccomend as well to make sure I am looking at the right thing.
It will be on a tv used mostly just for netflix, watching movies and a little gaming.
Thank you.
resnic is offline
post #2 of 2 Old 11-09-2012, 11:36 AM
Possumgirl's Avatar
Liked: 58
For your budget and needs, I'd suggest the Vizio VSB200. It's a basic soundbar but most owners seem quite happy with it. It doesn't come with a sub, but you could add one later if you choose to. You may find it locally at places like Wal-Mart and Costco. Online, Amazon has it new for <$100; Tigerdirect has refurbs for about $60.
http://www.amazon.com/VIZIO-VSB200-Universal-Sound-Bar/dp/B002EPF6YO
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=5279677&SRCCODE=WEBGOOPA&cm_mmc_o=mH4CjC7BBTkwCjCV1-CjCE&gclid=CK-tkdvCwrMCFUdxQgodHkAAoA
Possumgirl is offline
Reply Soundbars
