Why would I spend more for the Panasonic HTB450 over the 350? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-24-2012, 07:14 PM - Thread Starter
Sarah Jorgenson's Avatar
I understand that the 450 has an HDMI plug or something like that that is missing on the 350. Does that really matter? I am running my TV with an Antenna--no dish, no cable--all OTA. A BR player will be hooked up too.
Should I just run my BR to the TV with HDMI, and then run optical to the Soundbar?
Or should I spend the extra dough for the HDMI input so I can run the BR to the Soundbar?
I just bought a Harmony remote, so I'm not too worried about the multiple remote garbage that goes on...
Sarah Jorgenson is offline
post #2 of 4 Old 11-24-2012, 09:23 PM
nr5667's Avatar
It probably won't matter. Indeed, optical out from your T.V would be most convenient since that way you'd only need one audio link to the sound bar.
The only issue is if the optical output on your T.V only outputs in stereo, and not surround (dolby digital or dts). Of course, with a two speaker sound bar, that is of debatable importance... Since the soundbar has to convert any surround signal it receives to stereo anyway.
nr5667 is offline
post #3 of 4 Old 11-25-2012, 07:32 AM - Thread Starter
That's kind of what I was wondering about. A few people have posted reviews on Amazon complaining about the HDMI from BluRay would get converted to stereo in the TV, but wouldn't Dolby/DTS etc get converted to stereo by the Soundbar anyways?
It does cost $100 more too...
post #4 of 4 Old 11-27-2012, 10:31 AM
drfreeman60's Avatar
Liked: 52
If you connect your BlueRay directly to the TV and then output the TV to the soundbar, you will get two channel audio only as most TV's do not pass multi-channel from external sources (thank the music industry and digital rights management for this little bit of stupidity).
If you connect both the TV and Blu-Ray directly to the soundbar, you will pass the audio directly from the source, whether 2-ch, dolby digital, dts, etc.
I have listened to both the Panasonic HTB-350 and HTB-20 and ultimiately decided on the HTB-20 as it seemed to do everything as well as the 350 at a cost to me of about $ 100.00 less. After leaving the HTB-20 in place for about two weeks, it is now our primary device for audio from video sources. It does lack the blue-tooth connectivity available with t 350. Not sure if the 450 is the same as the 550. Have not seen in person or heard either of these units.
One caveat on most Panasonic soundbars is the subwoofer (or actually a woofer as I don't know of any soundbar less than $ 1,500 that comes with anything approaching a subwoofer). The two models I auditioned came with the woofer level set extremely high making the bass sound muddy and overwhelming. I turned the bass down almost to zero and increased it until it seemed in balance with the soundbar. I have not attempted to calibrate using test tones as I have not had time. I also turned off the 3-d effects as they seemed to add some sonic anomalies in my room. The simulated surround seems to work quite well as it throws an image far to the right and left of the actual device.
David Freeman
drfreeman60 is offline
Reply Soundbars
Panasonic Sc Htb350 Energy Star 2 1 Channel 240 Watt Multi Positional Audio System With Wireless Mus
