Can I use the TV remote to adjust the sound on this sound bar? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-28-2012, 09:44 PM - Thread Starter
Loyalty4Life's Avatar
http://www.amazon.com/Yamaha-ATS-1010BL-Factory-Refurbished-Surround/dp/B0077HED8O/ref=cm_cr_pr_product_top
After I plug this in with the optical cable that's provided, will I be able to adjust the volume up and down with my Comcast remote that controls the audio on the television? I just want to make sure before I buy it. Many many thanks. :-)
Loyalty4Life is offline
post #2 of 2 Old 12-05-2012, 01:03 PM
drfreeman60's Avatar
Liked: 52
Very doubtful. You would probably need a programmable universal remote like a Logitech. It was a Yamaha YSP that lead me to get my first Harmony remote in 2007. The remote was a better purchase than the soundbar.
David Freeman
drfreeman60 is offline
Reply Soundbars
