Samsung HW-E450 Soundbar and a P55ST50 Panasonic Plasma TV - AVS Forum | Home Theater Discussions And Reviews
Old 12-04-2012, 09:18 AM - Thread Starter
tm21's Avatar
What is the best way to connect you cable box, blu-ray to the P55ST50 and the Sansung HW-E450 so that you can take advantage of the full digital sound.
Thanks for your assistance
tm21 is offline
Old 12-04-2012, 10:22 AM
Possumgirl's Avatar
Liked: 58
You may want to review posts in the main HW-E450 thread as the subject of connectivity has been discussed often. Quick answer for you is connect BD player to soundbar and soundbar to TV via HDMI. Connect cable box to TV. You can use ARC or you can connect optical from cable box to soundbar.
Possumgirl is offline
Samsung Hw E450 Wireless Airtrack Soundbar , Panasonic Viera Tc P55st50 55 Inch Plasma Tv
