PolkAudio SoundBarBlack - Connection Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-06-2012, 04:46 PM - Thread Starter
DGCanuck's Avatar
I have a Denon 1713 and the subject surroundbar to test.
This is a 42" single speaker passive unit. I finally found the manual that says to hookup NOT the receivers aut setup this way:
For best music and movie sound quality performance in smaller rooms:
1. Connect the subwoofer (a PSW10) using the speaker level inputs connected to the same L & R front channel speaker outputs as the wires from the SurroundBar.
2. In your receiver’s Speaker Set-up Menu, set subwoofer to “Off,” “No” or “None.”
3. Set Left and Right speaker channels to “Large” and Set Center and Rear channels to “Small.”
4. In the receiver’s “Speaker Distance” Set-up Menu, select the same distance for all channels with a “Channel delay” to the minimum setting (in Ms) that it allows for the center and surround channels.
I was looking to just test the soundbar and then restore my current Denon settings after I re-connect the existing speakers.
Has anyone had experience with this or similar units who can confirm that the above makes sense or has other suggestions?
DGCanuck is offline
Reply Soundbars
Denon Avr 1713 Receiver
