Problem with HDMI Inputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-10-2012, 01:04 PM - Thread Starter
llaslo's Avatar
Hello, I just recently purchased a Panasonic Viera 50" Plasma TV (TC-P50UT50). It is great, but it only has two HDMI inputs, and I have 3 HDMI devices. I have a Panasonic 3D Blu-Ray player, U-Verse DVR, and XBox 360 (and likely will have a PS3 shortly). At any rate, I bought an HDMI switch (don't remember the brand / model, but it was $85.00) that said it supported 3D at Best buy, but it did not work when playing dvds or blu-rays. It was constantly skipping or pixelating during playback. This was not playing a 3D blu-ray, in fact, I was playing a DVD of ZombieLand. If I remove the switch box and plug the blu-ray player directly into the TV, the problem went away. All of that said, I'm looking for a solution. Do y'all have any ideas? i thought about getting a receiver and speakers, but I kind of hate to sink all that money into it. I'd actually much prefer to get a sound bar than a full-blown receiver, but I'm not sure any of them will suit my needs. If a receiver is the answer, I'd love some recommendations.
llaslo is offline
post #2 of 4 Old 12-10-2012, 02:04 PM
Selden Ball's Avatar
Quoted: 3046 Post(s)
Liked: 1494
It sounds like you might have a defective switch, bad cables or poor connectors. Unfortunately, price has very little relationship to quality frown.gif
Many people like the switches sold by Monoprice. Personally, I don't use them, so I can't recommend a particular model. Hopefully someone else can. At any rate, a Web search should provide some possibilites.
Selden
Selden Ball is online now
post #3 of 4 Old 12-11-2012, 08:59 AM - Thread Starter
llaslo's Avatar
Well, I ended up buying a Yamaha RX-v373 reciver that was bundled with a set of 5.1 speakers. I'm not a huge audiophile, but this should definitely meet my needs. I wanted to spring for the 473 so I could use the android tablet as a remote control, but since it didn't come bundled with any speakers, it would have ended up costing me a lot more money.
llaslo is offline
post #4 of 4 Old 12-11-2012, 09:36 AM
Liked: 1494
You seem to have gotten a reasonably good starter system.
Enjoy!
Selden
Reply Soundbars
Panasonic Viera Tc P50ut50 50 Inch Plasma Tv , Xbox 360 Console , Yamaha Rx V373 5 1 Channel Av Receiver
