samsung le 40r8 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-15-2012, 01:16 PM - Thread Starter
hutcho71's Avatar
does anybody know if the samsung le40r8 is arc compatible i have just bought a new home cinema system (samsung) as my old one had broken but not sure now if my television is compatible telivision is (5 years old approx) please help
hutcho71 is offline
post #2 of 10 Old 12-15-2012, 01:30 PM
Possumgirl's Avatar
Liked: 58
If your TV is older than a 2010 model it won't have ARC. You can look at the jack panel to see if any of the HDMI inputs say ARC. You can also look at your owner's manual. In any case, it shouldn't matter at all since ARC is just a convenience feature.
Possumgirl is offline
post #3 of 10 Old 12-15-2012, 01:40 PM - Thread Starter
hutcho71's Avatar
hi forgot to mention i have a set top box for extra chanells and the home cinema sytem only has one cable input so what your saying is the home cinema wont work through the television as its older than 2010?
hutcho71 is offline
post #4 of 10 Old 12-15-2012, 01:40 PM - Thread Starter
hutcho71's Avatar
hutcho71 is offline
post #5 of 10 Old 12-15-2012, 01:40 PM - Thread Starter
hutcho71's Avatar
hutcho71 is offline
post #6 of 10 Old 12-15-2012, 01:40 PM - Thread Starter
hutcho71's Avatar
hutcho71 is offline
post #7 of 10 Old 12-15-2012, 01:41 PM - Thread Starter
hutcho71's Avatar
hutcho71 is offline
post #8 of 10 Old 12-15-2012, 01:41 PM - Thread Starter
hutcho71's Avatar
hutcho71 is offline
post #9 of 10 Old 12-15-2012, 01:42 PM - Thread Starter
hutcho71's Avatar
hutcho71 is offline
post #10 of 10 Old 12-15-2012, 01:44 PM
Possumgirl's Avatar
Liked: 58
You might want to delete all your extra posts.
I said you don't need ARC. Post the model # of the cinema system you bought. How is your STB connected? HDMI to TV?
Reply Soundbars
