Soundbar Functionality - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-16-2012, 09:32 AM - Thread Starter
GeekRex's Avatar
Can someone explain why on earth HDMI enabled sound systems are run through the satellite box? That connection then only allows me to listen to the "TV" feed and not all that the SmartTV can do. This simply mystifies me since I've spent a couple hundred on a sound system that will only play part of what the TV can play. Why don't they build the sound system to play whatever the TV is displaying? mad.gif
GeekRex is offline
post #2 of 4 Old 12-16-2012, 10:00 AM
Possumgirl's Avatar
Liked: 58
You might want to add this question to the first thread you started so we can try to assist you all in one place. I see you also posted your initial issue in an existing thread. It makes it difficult for us to provide coherent answers when issues are split up in different places.
What you're describing here is related to the ARC issue you're having.
Possumgirl is offline
post #3 of 4 Old 12-16-2012, 03:15 PM - Thread Starter
GeekRex's Avatar
Thanks PG but I was asking a more general question about why some of these design decisions are made and then the consumer has to deal with them.
GeekRex is offline
post #4 of 4 Old 12-19-2012, 03:02 AM
nastymatt's Avatar
I think if you use the ARC on HDMI then you can get your SmartTV sound. The problem arises when you then use a universal remote mad.gif
nastymatt is offline
Reply Soundbars
