Soundbars and interference with low-profile, 3D 55" ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-16-2012, 09:34 AM - Thread Starter
dgdoc's Avatar
I've got a couple Panasonic 55" plasmas that sit very close to the base.
The IR sensor appears to be located about 2 1/8" from the base.
I'm concerned that most of the soundbars will block access and interfere with the 3D operation.
How much of a concern should this be?
Should I limit my search for soundbars under 2 1/8" high?
I've noticed that Panasonic's (better) soundbars are 3" high - Should I assume they've tested this?
dgdoc is offline
post #2 of 4 Old 12-16-2012, 10:19 AM
BobL's Avatar
Liked: 56
Something like the Yamaha YSP-2200which has an IR out so you can attach to your TV so the remote signals would work. There are also soundbars that go under your TV like the Zvox units that could also work. You could also place your TV on a small stand so the sound bar doesn't block the IR of the TV.
BobL is offline
post #3 of 4 Old 12-18-2012, 07:28 PM
Chicagorep's Avatar
the Bose soundbars are only 2.25" tall
Chicagorep is offline
post #4 of 4 Old 12-18-2012, 07:32 PM
Doctego's Avatar
Liked: 42
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
Reply Soundbars
Yamaha Ysp 2200 Digital Sound Projector Black
