Speakercraft CS3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 2 Post By Alfaguy
post #1 of 9 Old 12-24-2012, 12:59 PM - Thread Starter
BeerCan's Avatar
Anyone else have one of these? I just got on and so far I like it. A little on the expensive side but I needed a sound bar/box that I could actually put my TV on. It is similar in form factor to the zvox.
I will give a better impression once I have it for awhile.
http://www.speakercraft.com/products/subwoofers/passive-in-ceiling-subwoofer?page=shop.product_details&flypage=flypage_sc.tpl&product_id=360&category_id=85
BeerCan is offline
post #2 of 9 Old 12-27-2012, 01:48 PM
wolfereeno's Avatar
Can't wait to hear more. What made you pick it over the ZVOX?
Does it have a dialog enhancement mode in addition to the surround mode?
Several reviews mention the ZVOX 420 but I haven't seen a review comparing it with the more similar zvox 580.
wolfereeno is offline
post #3 of 9 Old 12-28-2012, 01:04 PM
Alfaguy's Avatar
My wife purchased one for her parents who are getting on in years. Since getting a Samsung LCD last year they have complained about intelligibility issues, She did some shopping around (at my suggestion) for a sound bar. She liked the idea of the under TV one box approach versus a separate sound bar / woofer, especially since her folks have the TV on a credenza. She did compare the Zvox (assume 580 because it was the $500 one) and found the SpeakerCraft to have much clearer dialog. Incidentally the spouse is a classically trained musician who knows what stuff is supposed to like. So I trust her judgement. The folks received the unit a few days before Christmas and are loving it - they live out of state from us so it had to be shipped. Apparently, it was also an easy install for them - PCM out from the TV into the box - done. OK so maybe not an audiophile review - but certainly a "real world" one.
EscapeVelocity and wolfereeno like this.
Alfaguy is offline
post #4 of 9 Old 12-28-2012, 03:08 PM
wolfereeno's Avatar
Thanks - I'm basically after something that yields the best dialog and general sound for normal TV watching. I have a pioneer plasma monitor that doesn't have its own speakers and have been using a pair of powered computer speakers for audio for the past couple of years. It works but it's ugly and its not great for dialog.
I'm a musician too. And I kind of hate the overwhelming aspect of most home theater setups. If I'm watching the Daily Show or sports I really don't need the seats to rattle. I've got drums for that!
We have a pretty good conventional 2 ch stereo in the same room for music and sometimes movies that we might want to really crank.
Thx
post #5 of 9 Old 12-29-2012, 07:28 AM
rcouret's Avatar
Can you sync the remote with the tv remote as you can with the zvox. Or in my case with directv remote.
rcouret is offline
post #6 of 9 Old 01-14-2013, 04:54 PM
JayF's Avatar
I purchased this last week and was shocked by how great it sounded compared with all of the other soundbars in Best Buy and Magnolia. It was even better at home with nice depth of sound without side walls to bounce soundwaves. The bass is incredible for the size of the unit. This past weekend I came across a B&W Panorama v1 on closeout for $1100 so I've been A/B'ing the last 2 days. The Speakercraft holds it own against the B&W which was originally $2200! I think the B&W outperforms with a tiny bit more dynamic range, but the Speakercraft is better in terms of sound depth and simulated surround. I haven't decided which one I will keep, but now I know the Speakercraft is a stellar performer. Is the B&W worth twice as much (on close out)? I'm not sure yet. Worth it at $2200? No way.
JayF is offline
post #7 of 9 Old 01-14-2013, 10:50 PM
MSIGuy's Avatar
The CS3 is a great sounding little package!
It does have a few issues, one being the dinky little remote that comes with it, but it's packed with features for something so simple and compact.
MSIGuy is offline
post #8 of 9 Old 02-26-2013, 09:32 PM
Chris009's Avatar
i saw this at bestbuy and it ook of the grille. I didn't get a chance to audition it but im a bit skeptical about the sound because the midrange drivers are very small in my opinion. I like the fact that it has a tweeter. so i kind of doubt the good reviews for this soundbar even though it looks well built
Has anyone listened to this and compared it to a zvox 580 for example?
Chris009 is offline
post #9 of 9 Old 08-07-2015, 01:52 PM
Liked: 0
Hello, I bought one of these and it does sound pretty good but the IR sensor doesn't work. I have tried with universal remotes but it ignores the commands.
Example
Press Volume Up 10 times and nothing happens
Press it two more times and the volume is deafening
Press Volume Down 20 times nothing happens
Is there any service centers that can look at this? I have contacted Speakercraft but they were not much help. I live in the Boston area but would consider shipping it.
Thank you
cstjohn17 is offline
Reply Soundbars
Zvox 4004201 Audio Z Base 420 Low Profile Single Cabinet Sound System , Zvox 580 Low Profile Single Cabinet Surround Sound System With Optical And Coaxial Digital Inputs
