JBL Cinema SB 400 - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 154 Old 09-17-2015, 01:35 PM
xxKNSxx's Avatar
Quoted: 16 Post(s)
So I just picked up this soundbar and im wondering the best way to configure this. My only device is my media box (Minix NX7) for XBMC (Kodi) right now I have hdmi going from the minix box to my tv and an optical going from the soundbar to the tv. Is this my best way of setting it up or should I be doing something different? Also im not sure exactly what my settings should look like in xbmc (kodi).
TV is a Sony Bravia KDL46EX500
xxKNSxx is offline
post #152 of 154 Old 12-13-2016, 10:48 PM
Liked: 0
JBL SB400 third party/universal remote?
TV is Panasonic TX-P46G30E – already has programmable/learning remote (No USB or other port available on it. Learning "over the air" only).
SB400 connected to TV through ARC HDMI.
Volume controls and mute work through Panasonic remote for the soundbar. Turn off possible, together with tv, but not turn on (only tv starts). Cannot (manually) start the soundbar without starting the TV, cannot turn off TV (via remote) without turning off the soundbar also. Advice?
Missing original JBL remote, thus nowhere to feed codes/macros the Panasonic remote from now (if even possible beyond the already achieved).
Thinking of buying one from Logitech Harmony remotes lineup, now that I have SB400 as the additional component in my system, to cover everything with one remote (SB400, TV, tv-box, media hub, remotely controlled power sockets, aircon...)
I think that the original remote is quite limited – Bluetooth has to be selected manually. Has anyone succeeded in programming the third party remote i.e. Logitech Harmony for the Bluetooth input selection (from the sofa), since not even the original remote can do it?
Nino XY is offline
post #153 of 154 Unread Today, 06:06 PM
resqguy's Avatar
Wall mounting
Just picked up an open box SB400. When I went to mount it to the wall I couldn't figure out how to attach the bracket to the soundbar.
Do I have the wrong bracket or am I missing something?
resqguy is offline
post #154 of 154 Unread Today, 07:35 PM
eric102's Avatar
Quoted: 21 Post(s)
Looks like maybe your bracket is for a shorter soundbar (hard to tell from the photo). The ears on the bracket should fit into those angled slots on either side of the hookups area if its the right one.
eric102 is online now
Reply Soundbars
Jbl Cinema Sb 400 Plug N Play 2 X 60 Watt Soundbar System , Harman Kardon Sb 30 5 1 Soundbar And Wireless Subwoofer
