Yamaha YAS101 or Sony HTCT260? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-01-2013, 08:51 AM - Thread Starter
id_mew's Avatar
I'm deciding between the Yamaha YAS101 http://www.futureshop.ca/en-CA/product/yamaha-yamaha-front-surround-system-yas101-yas101/10178417.aspx?path=7abc9a88cee6a4395ba590fdb5587c7cen02
And the Sony HTCT260 http://www.futureshop.ca/en-CA/product/sony-sony-sound-bar-with-wireless-subwoofer-htct260-htct260/10224187.aspx?path=c1074f0836a669a866c48e9ff9fce60den02
Witch one do you guys recommend? They are both the same price right now, and I would like to get one before the sale is over.
I mostly gonna use it for Netflix, and some gaming on my 360 and PS3.
id_mew is offline
post #2 of 3 Old 02-26-2013, 09:25 AM
Andrew Scarella's Avatar
Hi,
i have been trying to decide between both of these as well. Did you end up making a purchase? I think the sound quality from the yamaha would be better, but I like the HDMI plugs, bluetooth and sub from the Sony.
thanks
Andrew Scarella is offline
post #3 of 3 Old 02-26-2013, 04:18 PM
bigcam406's Avatar
i bought a Yamaha YAS101 and ive been really impressed with the sound quality.as far as hookups,if they are a requirement,then go with the Sony.
bigcam406 is offline
Reply Soundbars
Yamaha Yas 101bl Front Surround System Piano Black , Sony Htct260 Sound Bar Home Theater System
