crystal surround air track hw-e450 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-01-2013, 01:32 PM - Thread Starter
danmeyer's Avatar
blue tooth with my iPhone 5 works fine for playing music but when i direct plug it in with the USB cable is says NO USB and i cannot get it to work. any ideas?
danmeyer@usmailinghouse.com
danmeyer is offline
post #2 of 2 Old 01-01-2013, 04:15 PM
Doctego's Avatar
Liked: 42
There's a huge dedicated thread here for that exact soundbar.
As for your exact issue, I decided to test it out as I hadn't previously. It didn't work for me with my iPhone 4S, either. I wasn't sure if it would because the manual said that you could connect external storage devices such as MP3 players via USB but it also said that you should use the included USB cable for such applications. I can confirm that connecting a 3.5mm cable from the headphone jack on the iPhone to the AUX input on the soundbar works fine.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
Reply Soundbars
Samsung Hw E450 Wireless Airtrack Soundbar
