Soundbar recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-01-2013, 06:11 PM - Thread Starter
Rajdawg73's Avatar
I was recommended because of the setup in my room to get a soundbar that produces a left,center,and right channel. That I can hook into my av receiver
What models should I look at? I really wouldn't like to spend more than 300 or so on it. Is that possible?
Sent from my iPad using Tapatalk HD
Rajdawg73 is offline
post #2 of 4 Old 01-01-2013, 07:48 PM
Doctego's Avatar
Liked: 42
What is it about the setup of your room that you wouldn't just pick up some speakers instead of a sound bar? I always think of a sound bar as an option when an A/V receiver isn't a good option.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
post #3 of 4 Old 01-01-2013, 08:20 PM - Thread Starter
Rajdawg73's Avatar
My room has a sectional and I would have to ceiling mount the front and left speakers due to the setup of the room. That is what I would prefer to do
post #4 of 4 Old 01-01-2013, 08:29 PM - Thread Starter
Rajdawg73's Avatar
Here is a very crude sketch of my room
Reply Soundbars
