i need help!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-02-2013, 11:15 PM - Thread Starter
meladdav's Avatar
i have a samsung pdp 450 51" with two hdmi outputs. i have it connected to a mac desktop and use the tv as a monitor for the comp via hdmi.
i just got a samsung hw e450 soundbar and whooffer, it has one hdmi in and 1 hdmi out., aux, bluetooth set up. and a spot for optical cable
i cannot get sound out of the sound bar after numerous tries
. can anyone help???
meladdav is offline
post #2 of 5 Old 01-03-2013, 04:39 AM
Doctego's Avatar
Liked: 42
What are all of the sources that you have connected and how do you have them connected right now?
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
post #3 of 5 Old 01-03-2013, 09:48 AM
Possumgirl's Avatar
Liked: 58
How did you connect the TV and the soundbar? in order to get audio for anything connected to the TV, you need to use an optical (toslink) cable from the TV to the soundbar.
Possumgirl is offline
post #4 of 5 Old 01-03-2013, 12:10 PM - Thread Starter
meladdav's Avatar
thats the one thing im missing. an optical cable. i will pick one up today.
i unplugged everything. so nothing is connected right now. but usually i have an hdmi hook up from my imac to my tv. and another one hooked up from my tv to my ps3.
i even tried using the bluetooth option and connecting it to my imac but after all the steps it still says not connected.
do i need to have everything plugged in (both hdmi's, aux, and the optical cable) or are they just different kinds of ways to connect them?
after i pick up the optical cable what are the steps i need to take?
thank u for your responses
meladdav is offline
post #5 of 5 Old 01-03-2013, 12:30 PM
Doctego's Avatar
Liked: 42
When you get the optical cable, the easiest thing to do is connect everything to the TV and then connect the optical out from the TV to the soundbar. In the interim, you can hook up an individual source directly to the HDMI IN on the soundbar and then connect HDMI OUT from the soundbar to the TV.
You do NOT need to have sources connected to every input on the soundbar. Assuming it is done correctly, 1 method will suffice.
Doctego is offline
Reply Soundbars
Samsung Hw E450 Wireless Airtrack Soundbar
