Help needed to select the soundbar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-07-2013, 12:29 PM - Thread Starter
soundphobia's Avatar
Just bought Panasonic st50 3d TV and in the market looking for a sound bar. My budget is close to 500 give or take a few.. Now I have been looking at HK SB16. However I am concerned about its integration with my TV. Wondering if it will cause any issue with annoying message when you are trying to adjust volume on the Panasonic ST50.
Also, the wireless sub woofer could cause the interference with router and other wifi devices. Is there a solution for this. If not how big an annoyance is this.
Any other ideas about what I could look for in my price range. Other equipment that I will pair up in some shape or form is PS3 and Cable box.
Thanks for your help.
soundphobia
soundphobia is offline
Reply Soundbars
Harman Kardon Sb16 Soundbar And Wireless 100 Watt Subwoofer Black
