Vizio's New True 5.1 Soundbar S4251W - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #451 of 1075 Old 01-28-2014, 01:57 AM
Infinite Xero's Avatar
Quoted: 12 Post(s)
Originally Posted by JD4L View Post
If you select bitstream dts you will get the best audio but that requires switching the optical audio cable from sound bar to tv to sound bar to ps4.
When I set this option on my PS4, the soundbar still flashes Digital, indicating true 5.1 audio. So why would I need to remove the optical cable from my TV and put it into my PS4?
TV: VIZIO M501d-A2
Speakers: VIZIO S4251w-B4​
Infinite Xero is offline
post #452 of 1075 Old 01-28-2014, 07:58 AM
SlackerCSB's Avatar
I have a Vizio 70" e701ia3 TV. If I run all my components into the TV (XBox, Comcast, Etc) and run the audio from the TV to the soundbar, will I get true 5.1 sound?
SlackerCSB is offline
post #453 of 1075 Old 01-28-2014, 08:04 AM
Bond 007's Avatar
Quoted: 2372 Post(s)
Liked: 1909
No.
Licence to Kill
Bond 007 is online now
post #454 of 1075 Old 01-28-2014, 08:08 AM
SlackerCSB's Avatar
What if I run all the components into my Onkyo receiver and then run the audio out to the sound bar. Would that be 5.1?
post #455 of 1075 Old 01-28-2014, 08:12 AM
Bond 007's Avatar
Liked: 1909
Just because it flashes "Digital" does not mean its 5.1. 99% of tvs will not output 5.1 from an external source via optical. The tv will downconvert it to 2.0. If you hook directly from the PS4 to the soundbar then you will get 5.1.
Licence to Kill
post #456 of 1075 Old 01-28-2014, 08:13 AM
Bond 007's Avatar
Liked: 1909
Yes
Licence to Kill
post #457 of 1075 Old 01-28-2014, 10:17 AM
mercennarius's Avatar
Quoted: 75 Post(s)
Liked: 36
Many newer TVs output DTS and DD via optical from an external source. I know mine does and this soundbar switches between "dolby Digital" and "DTS" depending on what is playing on the TV.
mercennarius is online now
post #458 of 1075 Old 01-28-2014, 12:01 PM
naustin's Avatar
Quoted: 334 Post(s)
Liked: 138
Originally Posted by skellogg02 View Post
Bump, anyone have similar issue?
I believe you are having the 2.0 versus 5.1 perception issue discussed above, hearing sounds out the rears when you turn dolby digital off. If you like hearing the rears all the time you can go back to running thru your TV. I don't think you have Sound bar problem, but as a test watch a Bluray action movie with the optical connection.
naustin is offline
post #459 of 1075 Old 01-28-2014, 12:02 PM
Bond 007's Avatar
Liked: 1909
I didnt say 99% of tvs wouldnt output DTS and DD from an external source. I said they would not output 5.1 from an external source. The tv will downconvert the 5.1 signal to a 2.0 signal. And I just about guarantee your tv is doing that.
Just because it says "Dolby Digital" or "DTS" does not mean its 5.1. This is something that the makers of soundbars would never tell you. Soundbars are not meant to replace a multimedia AVR and true surround system. They are designed to be better than the tv speakers for OTA tv and the built in apps that many of todays Smart tvs have. As is usually the case you get what you pay for.
What kind of tv do you have?
Licence to Kill
post #460 of 1075 Old 01-28-2014, 12:06 PM
JD4L's Avatar
Quoted: 24 Post(s)
There's a dts light too but it only works if you run optical from sound bar to ps4
JD4L is offline
post #461 of 1075 Old 01-28-2014, 12:09 PM
JD4L's Avatar
Quoted: 24 Post(s)
I run mine from soundbar to tv and I got 5.1 on cable box xbox and blu ray player the only thing I can't get is dts unless I run optical from soundbar to blu ray player... Even tho my vizio says it does dts.... Frustrating
JD4L is offline
post #462 of 1075 Old 01-28-2014, 12:11 PM
naustin's Avatar
Quoted: 334 Post(s)
Liked: 138
As a point of information, Some Dolby digital is encoded as 2 channel only. Most network shows are 5.1 encoded but most PBS in Dolby digital 2.0. I know because my Onkyo AVR receiver shows the source signal.
naustin is offline
post #463 of 1075 Old 01-28-2014, 12:13 PM
Bond 007's Avatar
Liked: 1909
How do you know you are getting 5.1 from your bluray player?
Licence to Kill
post #464 of 1075 Old 01-28-2014, 12:19 PM
JD4L's Avatar
Quoted: 24 Post(s)
I have tested all kinds of methods and the sound is identical when using dd5.1 running optical from tv to sound bar or running optical to blu ray player unless I switch to dts then I notice better bass but when running from tv to sound bar It's very crisp and if it was making it run 2.0 wouldn't that be same as RCA?? I've also switched from RCA to optical during movies and there is a huge diff in quality of the sound and vizio rep said that when the light comes on you are getting 5.1 which I guess May not always be true but I know it is for me and they said I should be able to get dts but for some reason I can't.... Maybe I need a soundbar firmware update
JD4L is offline
post #465 of 1075 Old 01-28-2014, 12:20 PM
Bond 007's Avatar
Liked: 1909
Exactly. DD and DTS can be 2.0, 2.1, 5.1, 7.1, 7.2 and anything else. Just because it says DD or DTS does not make it 5.1. And if you have a soundbar how would you know the difference? How would you know that the soundbar is not just simulating surround with something like Dolby ProLogicII? You wouldnt because the soundbar does not tell you exactly what kind of signal it is receiving. The makers do that on purpose because if it did tell you exactly what the signal was a lot of people would be very disappointed to find out that they are listening to everything in simulated surround instead of true 5.1.
Licence to Kill
post #466 of 1075 Old 01-28-2014, 12:27 PM
JD4L's Avatar
Quoted: 24 Post(s)
I can hear the difference
JD4L is offline
post #467 of 1075 Old 01-28-2014, 12:31 PM
Bond 007's Avatar
Liked: 1909
The Vizio rep told you its 5.1 when the,light comes on because hes a Vizio rep.
And the sound is not "identical". No offense but you just cant tell the difference when switching. If you had a way to do it A/B you would notice the difference.
No its not the same as 2.0 through RCA. The soundbar is most likely using Dolby ProLogicII to fake 5.1 and that format is not supported by RCA.
Licence to Kill
post #468 of 1075 Old 01-28-2014, 12:33 PM
Bond 007's Avatar
Liked: 1909
Sure. Youre hearing the difference between Dolby ProLogicII and Stereo. Neither of which is 5.1.
Licence to Kill
post #469 of 1075 Old 01-28-2014, 12:34 PM
naustin's Avatar
Quoted: 334 Post(s)
Liked: 138
+1 on that! Most people want a simulated sound that throws sound out of 5 speakers all the time (getting their monies worth). I wish the sound bar had more digital inputs so I could ditch the AVR,
naustin is offline
post #470 of 1075 Old 01-28-2014, 12:35 PM
JD4L's Avatar
Quoted: 24 Post(s)
You could be right for most ppl but I keep one optical from tv to bar and keep one in blu ray player and the other end sitting next to the bar so when I switched it literally took 2 seconds an have notice noooo difference
JD4L is offline
post #471 of 1075 Old 01-28-2014, 12:40 PM
Bond 007's Avatar
Liked: 1909
If you are running the optical directly from bluray to the bar then you will get 5.1. Now if you also do that for your cable box every time you want to watch cable you will be set.
Licence to Kill
post #472 of 1075 Old 01-28-2014, 12:46 PM
Bond 007's Avatar
Liked: 1909
You get what you pay for. Really if you have an AVR I would never go with a soundbar. Youre paying too much for convenience and inferior sound. You could just buy some nice speakers for the same money and have 2.0, 3.0, 3.1 or even a decent true 5.1 setup for what some of these soundbars that come with ultra cheap speakers and sub. Then you throw in wireless and the sound suffers even more.
Licence to Kill
post #473 of 1075 Old 01-28-2014, 12:58 PM
Quoted: 75 Post(s)
Liked: 36
This soundbar does decode DTS and DD and outputs true surround. On the Vizio S4251W, every time it lights up Dolby Digital or DTS, my speakers are outputting true surround. My TV is an LG 55GA7900 and does pass through DTS and DD through the optical port.
post #474 of 1075 Old 01-28-2014, 01:12 PM
Bond 007's Avatar
Liked: 1909
Never said it didnt decode DTS and DD.
As for the rest of your post...ok if you say so. I suggest you do some research on surround sound.
Licence to Kill
post #475 of 1075 Old 01-28-2014, 01:15 PM
Bond 007's Avatar
Liked: 1909
Post over in the owners thread for your tv and ask them if youre tv will output 5.1 from optical with an external source and see what they say.
Licence to Kill
post #476 of 1075 Old 01-28-2014, 01:24 PM
JD4L's Avatar
Quoted: 24 Post(s)
If I leave my blu ray player set to bitstream Dolby 5.1 there is no diff in the sound at all no matter where the optical cord is plugged into... The only way I get better sound is by changing the blu ray player settings to bitstream dts then running the cord to blu ray player
JD4L is offline
post #477 of 1075 Old 01-28-2014, 01:25 PM
JD4L's Avatar
Quoted: 24 Post(s)
JD4L is offline
post #478 of 1075 Old 01-28-2014, 01:30 PM
Bond 007's Avatar
Liked: 1909
Youve said that many times. I believe that is what you hear. Do you have a question?
If the Vizio has HDMI why dont you buy an HDMI cable?
Licence to Kill
post #479 of 1075 Old 01-28-2014, 01:31 PM
JD4L's Avatar
Quoted: 24 Post(s)
Just trying to get my point across that I'm getting 5.1 and because this sound bar doesn't have hdmi
JD4L is offline
post #480 of 1075 Old 01-28-2014, 01:34 PM
Bond 007's Avatar
Liked: 1909
And Im trying to get my point across that if you have the optical cable coming from the tv to the soundbar while watching a bluray you are NOT getting 5.1. I can care less if you think you can hear the difference or not. I will not type that again. Enjoy.
Licence to Kill
Reply Soundbars
Vizio S4251w B4 5 1 Soundbar
