Vizio's New True 5.1 Soundbar S4251W - Page 34 - AVS | Home Theater Discussions And Reviews
post #991 of 1012 Old 02-15-2015, 11:23 PM
cl0ckw0rk's Avatar
Quoted: 23 Post(s)
Originally Posted by sethsez View Post
Sorry to repeat the question, but can anyone confirm if they get distinct left and right surround channels with test audio?
Here's some links to some tests:
http://www.demo-world.eu/trailers/re...nnel_check.jpg
http://www.mysurround.com/en/info-test
http://www.wooferbasstest.com/downlo...1ch-sound-test
Each of these just play a sound effect out of one speaker at a time. With a true 5.1 setup playing these properly, there should be no crossover between any of the channels until the end when they all play at once. On my setup (and apparently I'm not alone here) the front three channels work fine, the sub works fine, but the surrounds are combined, and that's with a direct optical connection from a source that works perfectly on my other 5.1 setup and which lights up the Dolby sign on the soundbar. I'm wondering if this is an issue with our setups we're not seeing, if it's a problem that affects some of these, or if it's just an inherent part of how this works.
Quoting myself just to follow up on this... I called Vizio and asked about this behavior. Long discussion short, yep, this is working as intended. A mono signal is sent to the surrounds and then expanded to cut down on latency since it's a wireless connection. Because of this, using a true 5.1 signal is only somewhat better than using fake surround processing: it doesn't simulate what gets sent to the surrounds, but it still simulates what happens there.
Unfortunately for me, that means I'm going to be returning it. I really do like how it sounds on a technical level (at least as far as soundbars go), but I find fake surround effects using real surround speakers to be more distracting than involving, and that's the entirety of how this particular unit works. A shame, but hey, I'm glad it fits the bill for some people, even if it doesn't for me.
I know that this is a slight bump, but I picked up this system today to mate with my Vizio P series LCD.
When playing the "Test Patterns" video using the built in Netflix app (this video runs test patterns up to 4k but also tests for surround/discreet audio) I can correctly hear the test samples (it does left, right, center, sub, left surround, then right surround).
cl0ckw0rk is offline
post #992 of 1012 Old 02-17-2015, 01:55 PM
quake1028's Avatar
Quoted: 12 Post(s)
I got one, and my head is spinning. Right now I have my Vizio TV connected to the soundbar with toslink, but I am sure that is not going to work out. Will this work:
Soundbar ---> toslink hub ---> PS4/PS3/XBO
Cable box ---> digital coax ---> soundbar
That's going to the only real way to get 5.1 from everything, right?
Main - LG 65LM6200 3D TV | Vizio S4251w-B4 | Harmony 650 | PS4 | PS3 SS | Wii U Dlx | Xbox One
HD DVD Collection | Blu-ray Collection | DVD Collection
quake1028 is offline
post #993 of 1012 Old 02-18-2015, 07:15 PM
tiki master's Avatar
What kind of vizio tv do u have (model/year)? Most recent vizio tvs pass 5.1 thru their optical output. So u can connect everything to your TV via hdmi then connect optical/toslink from TV to soundbar. I have dish box, ps3, and ps4 set up this way with a 2014 M series vizio and I get 5.1 from every source.
tiki master is offline
post #994 of 1012 Old 02-18-2015, 08:17 PM
pjp
pjp's Avatar
Quoted: 21 Post(s)
This is quite surprising since it seems many of us were unable to get discrete audio out of each channel with BluRay test discs. Also, there was a post here indicating Vizio support stated that the left/right surrounds were combined on the soundbar, so you the get the sum of the audio to both surround speakers rather than left/right discretely to each surround.
Were you able to adjust the levels to get uniform volume out of all speakers with the test signals?
pjp is offline
post #995 of 1012 Old 02-18-2015, 09:00 PM
I tried the calibration portion found on The Incredibles Blu-ray disc and noticed that both rear speakers do play at the same time but one plays louder than the other. For instance if the sound is supposed to come from the left rear speaker, then both rear speakers make the sound, but the left rear speakers is significantly louder than the right and vice versa.
pjp likes this.
post #996 of 1012 Old 02-19-2015, 06:37 AM
quake1028's Avatar
Quoted: 12 Post(s)
VO420E, it's around 6-7 years old at this point I think.
post #997 of 1012 Old 02-19-2015, 07:04 AM
Hmm I'm not sure about that model. Try going into the audio output settings in ur TV menu and see what the options are. For 5.1 output on the current tvs you need to select "bitstream".
post #998 of 1012 Old 02-19-2015, 08:46 AM
quake1028's Avatar
Quoted: 12 Post(s)
Per the manual under the digital audio menu: The options are OFF, Dolby Digital and PCM.
post #999 of 1012 Old 02-19-2015, 10:40 AM
cl0ckw0rk's Avatar
Quoted: 23 Post(s)
I did not make any volume adjustments, and it would be difficult to as it's just a looping checklist. I recommend running it if you want to check it out.
This is possible and I just didn't notice.
What I can advise as that a proper directional sound field exists (i.e things that you are supposed to hear to your rear left, you hear from your rear left. Things that you are supposed hear from the rear right, you hear from your rear right)
I was also able to test this playing GTA V on my PS4 via sounds from other traffic and pedestrians.
post #1000 of 1012 Old 02-19-2015, 01:53 PM
Choose dolby digital.
post #1001 of 1012 Old 02-20-2015, 07:56 AM
quake1028's Avatar
Quoted: 12 Post(s)
Thanks I will try that out tonight.
post #1002 of 1012 Old 02-20-2015, 08:34 AM
Liked: 0
This sound bar looks amazing. But I think that Yamaha has made something better than this.
best_2015 is offline
post #1003 of 1012 Old 02-20-2015, 09:53 AM
pjp
pjp's Avatar
Quoted: 21 Post(s)
What is attractive about the Vizio, at least to me, is the wireless sub feeding the satellites, because that form factor eliminates the need for front to back wiring in the room. Also, real 5.1 with rear speakers beats simulated surround by a wide margin in my experience.
That said, I think the audio quality is just OK on the Vizio (and on most soundbars frankly). Also, the 5.1 implementation is a quite weird on the Vizio because it combines the left/right signals on the surround speakers to at least some extent. The real 5.1 killer for me though is that it isn't possible to adjust sound levels equally because: 1) The 5.1 implementation is too weird to properly handle test signals for adjustment with an SPL meter; and 2) The speaker trim controls don't have enough range or control to balance levels with whatever limited test signals you are able to force through it.
I've had the Vizio for a few months and have yet to hear any left/right directionality out of the front soundbar for this reason (even with center channel level turned down to minimum). You might hear some directionality if you sit towards the front of the room, but from our back of the room viewing there is none (at least in our setup).
If you are a casual AV fan, the Vizio performance might be good enough and the form factor is GREAT. If you are hardcore A/V, it's limitations might frustrate you.
I'm not sure there are any other affordable soundbars that sound great, so I will probably dump the Vizio and replace it with a small true (non-soundbar) 5.1 system.
Hope this helps!
pjp is offline
post #1004 of 1012 Old 02-20-2015, 09:57 AM
toneroni's Avatar
Quoted: 14 Post(s)
Maybe try the 54 inch version for $299 at Costco currently.
Some reviews says it splits the left and right a bit more.
I might get that one since the 42 looks a bit small under the 65" tv
toneroni is offline
post #1005 of 1012 Old 02-20-2015, 06:36 PM
quake1028's Avatar
Quoted: 12 Post(s)
Didn't work. As soon as I go tv ---> soundbar via optical, even with the setting on Dolby Digital, I lose that functionaility on the soundbar.
post #1006 of 1012 Old 02-21-2015, 11:50 AM
Charles Tintera's Avatar
Quoted: 66 Post(s)
I have two problems with the soundbar.
1 - one of our house cat's loves to lick the fabric. (It's a cat, 'nough said😀.
2 the port faces right as I have it potion ed and wifie complains about too much bass.😀😀😮.
Charles Tintera is online now
post #1007 of 1012 Old 02-21-2015, 09:08 PM
What functionality are you losing?
post #1008 of 1012 Old 02-23-2015, 10:06 AM
quake1028's Avatar
Quoted: 12 Post(s)
Legit 5.1. Hooked up directly from the XBO, I get the DTS and/or Dolby logo to flash when appropriate. Hooked up directly from the TV, I get no such logos.
post #1009 of 1012 Old 02-23-2015, 11:21 PM
I guess your TV doesn't pass 5.1 via optical, which is weird cuz I thought the Dolby Digital setting would. I would try an optical switcher and see if that works.
post #1010 of 1012 Old 02-24-2015, 11:37 AM
quake1028's Avatar
Quoted: 12 Post(s)
I think I am just going to do what I said above:
naustin likes this.
post #1011 of 1012 Old Today, 06:08 AM
mountlaurel's Avatar
Been having problems with this sound bar ever since I updated the firmware to 1017. The issue is when I fast forward thru commercials using my TIVO the "Dolby Digital" light does not come back on and it seems that it's back PCM. The firmware is correct when I checked the lights. Could my Optical Cable be broken causing this? Need advise.
mountlaurel is online now
post #1012 of 1012 Old Today, 02:59 PM
Quoted: 66 Post(s)
I expect that if you broke an optical cable there would be no signal coming thru.
Reply Soundbars
Vizio S4251w B4 5 1 Soundbar
