Vizio's New True 5.1 Soundbar S4251W - Page 35 - AVS Forum | Home Theater Discussions And Reviews
post #1021 of 1034 Old 07-03-2015, 04:38 AM
mountlaurel's Avatar
Just curious if anyone else has this problem. Since I updated the firmware to 1017 when I use 30 second skip or fast forward thru commercials using my Tivo Premiere (w/Dolby Digital setting with Tivo) at some point during the recorded show I hear "Popping or Crackling" sound and then I lose the Dolby Digital Light on the Sound bar and I can tell something has gone wrong. Talked to a Vizio engineer and he believes that the vizio firmware just doesn't like the Tivo software. Please reply back with any suggestions or others that are experiencing this problem. Thanks
mountlaurel is offline
post #1022 of 1034 Old 07-03-2015, 10:59 AM
naustin's Avatar
Quoted: 43 Post(s)
Try to duplicate the problem in the middle of a Dolby program, not a commercial. It is possible it is the audio in the non Dolby commercial. How are you connected to the SB & your TV? Are you using TruVolume? With my 54 incher I occasionally (once or twice a day) get a pop during skips on my Dish DVR. I use an optical from my source to the Bar and HDMI to the TV.
naustin is online now
post #1023 of 1034 Old 07-03-2015, 03:16 PM
Yes using TruVolume. Lose the Dolby Digital light when skipping thru commercials or anywhere during the recorded program.
post #1024 of 1034 Old 07-03-2015, 07:01 PM
nxmehta's Avatar
Can I ask, how did you manage to talk to a Vizio engineer? Did you somehow get your call elevated when calling customer service?
I would love to ask one of them about the subwoofer volume issues that plague these units.
nxmehta is offline
post #1025 of 1034 Old 07-03-2015, 08:45 PM
naustin's Avatar
Quoted: 43 Post(s)
Ok you lose the light everywhere, but do you get the popping when test skipping in regular programming? You might want to try turning TruVolume off and see if things improve.
post #1026 of 1034 Old 07-04-2015, 05:28 AM
Sometimes a get poping before i lose Dolby digtal light. That's when I know when it's going to happen again. I think I tried turning off the TruVolume and it still did not resolve the issue.
post #1027 of 1034 Old 07-06-2015, 05:38 AM
Does anyone know what the original Firmware (number) was for 4251w-b4? Currently using 1017 which has bugs.
post #1028 of 1034 Old 07-23-2015, 10:40 PM
wekya's Avatar
Quoted: 30 Post(s)
I will go back and read the entire thread, but thus far I've only read the last page, sorry. Has anyone tried using different speakers than those supplied by Vizio as satellites? I was thinking about buying a pair of KEF eggs and replacing the stock rears with them. Does the amp in the subwoofer have enough oomph to drive other, more quality, speakers?
Acer Revo RL100 HTPC Win7 64;1.3Hz Athlon II Neo K325 Dual Core;4GB 1,066MHz DDR3;512MB (shared) Nvidia GeForce GT9400 (Ion) OR Oppo 105D>Panasonic P50ST60.
Audio: Oppo 105D>Linn 5125>Aktiv Katans(K400 and Linn silver RCA), OR Optical out from Oppo>Vizio S4251w-B4 5.1
Synology 215j, Asus N66U router
wekya is online now
post #1029 of 1034 Old 07-24-2015, 10:34 AM
naustin's Avatar
Quoted: 43 Post(s)
Maybe. I'm using the 54 incher, which probably has a few more watts with small Inifinty minuettes (2 way w/15-80w rms power handling). To further minimise power issues stick with an 8 ohm speaker.
I wouldn't recommend buying new rear speakers, since these systems are supposed balanced. I already had the Minuettes from my former 5.1 AVR setup and they were similar in driver size. Doing a bit of switching between the Vizio & Minuettes didn't produce much sonic difference, but I prefer a separate tweeter.
post #1030 of 1034 Old 07-25-2015, 05:11 PM
Liked: 0
How does the 5.1 compare to the S4221W-C4?
sndr15 is offline
post #1031 of 1034 Old Yesterday, 01:00 PM
wekya's Avatar
Quoted: 30 Post(s)
Thanks, good to know. You're probably right, as any quality output is driven by the electronics and general fidelity of the bluetooth-ish connection and whatever crossover-ish system they are using. Given that the Infinity's were free to you, would you say the upgrade was worth it. Out of ten, rate the stock Vizio vs. your upgrade if you could please.
wekya is online now
post #1032 of 1034 Old Yesterday, 01:35 PM
naustin's Avatar
Quoted: 43 Post(s)
I'd say a 7 for the Vizio rears and maybe an 8 for the Infinitys. Very minimal with this soundbar, whereas with my AVR I'd have given the Infinitys a 10.
post #1033 of 1034 Old Today, 12:42 AM
wekya's Avatar
Quoted: 30 Post(s)
Sorry, too many acronyms, what is AVR?
wekya is online now
post #1034 of 1034 Old Today, 01:00 AM
naustin's Avatar
Quoted: 43 Post(s)
Audio Video Receiver 5.1 system where I used the Infinitys for the rear speakers/
Reply Soundbars
Vizio S4251w B4 5 1 Soundbar
