Can someone who owns this system please take/post a picture of one of the satellite speakers from under the speaker? I need a shot of the underneath part of one of the small speakers to see how im gonna fit them on a speaker stand. I would very much appreciate it.
You know, this is just weird as I am looking to use a sound bar in our motor coach.
The issue here, with this, from what I can tell, is you can not get true 5.1 out of the system with the way they show it connected. (Unless I am totally mistaken.)
By this I mean...If you pass though a TV and come optical out to the sound bar, you actually only get 2.0 out of the TV. Again, unless I am totally wrong, the HDMI standards do not allow for TV's to pass though anything but stereo.
So, if you care coming out of a Blu-ray via HDMI, into your TV, and then Optical out from your TV into the sound bar, the TV can only pass 2.0 out.
I ran into this, discovered this, when I was messing with XBMC on my HTPC. Setting the HTPC to send out 5.1 via HDMI to the connect TV, it can't play unless I set it in Analog 2.0 mode. Doing some research into this, I found that it is a HDMI standards issue in regards to passthrough.
The TV can pass 5.1 out ONLY if it is using it'd internal OTA tuner.
So...why it is nice for OTA TV, it seems you can not get 5.1 if hooked up to the TV as they show it should be hooked up.
Not just an issue with this bar, but anything. But this bar is the only one that I know is doing 5.1 and saying it can do 5.1. It can, but it surely seems to be misleading. As what you get via a passthrough is simulated surround at best. (Dolby ProLogic if you will.)
I've just started looking at sound bars and wondered why most all are only 2.1 and most do not have HDMI.
I do think it comes down to the no passing a 5.1 via HDMI through a display which makes no sense to me whatsoever.
Seems like the only way to get a 5.1 signal is if your cable\sat box has any extra HDMI out or to use a splitter to input to the sound bar and bypass the display totally.
If you're using a BD player, the bar has to have HDMI input to pass a lossless sound track as well.
Originally Posted by Milt99 /t/1451371/vizios-new-true-5-1-soundbar-s4251w/150#post_23693437
Originally Posted by bowlopho /t/1451371/vizios-new-true-5-1-soundbar-s4251w/150#post_23734601
I am sorry to say in that config you will not be sending 5.1 to the sound bar as the TV is not allowed to pass it. While the cable box may send 5.1 to the TV, from that point it made into 2.0 as a pass through.
No matter as the sound bar is only 2.0 anyway so you are not loosing anything. (Note...someone might way 2.1 with the sub, but it is really 2.0 as the sub is only their for low end and not LFE which is the .1 channel)
Actually, this particular soundbar is 5.1 because it has the two wireless rear speakers.
As far as the TV passing 5.1, it might. It has been reported for some time that some Sony TVs pass 5.1 from connected source devices I don't know if the KDL is one of those models.
Additionally, I recently learned that some cable boxes have a setting (probably under audio or HDMI) where you can specify "auto" or "pass through". With the "pass through" setting, 5.1 from the cable box was indeed passed through and output as 5.1 by the TV. I've no idea if that works only with some cable boxes and/or some TVs.
Originally Posted by David Bott /t/1451371/vizios-new-true-5-1-soundbar-s4251w/150#post_23741224
so you're saying the vizio s4251 which has a front speaker with left (1) center(1) and right (1) channel, sub (0.1), and rear speakers (2) (advertised as 5.1 audio system) is truly only 2.0?
and my sony kdl70r550a does not output 5.1 ch audio out as specified in the product manual is wrong?
ALL HDTVs will output 5.1 from internal sources (tuner, smart apps). However, most will NOT output 5.1 from attached source devices like a cable box. Whether your KDL is one of the Sonys that pass 5.1 is unknown.
Originally Posted by Possumgirl /t/1451371/vizios-new-true-5-1-soundbar-s4251w/150#post_23741443
I do hear audio from my rear speakers when I watch from my cable box. I am not an audio expert, so is there a possibility that it's simulating or creating the 5.1 audio? or would I not hear anything from the rear speaker if my tv was outputting as stereo 2.0/2.1?
Originally Posted by Possumgirl /t/1451371/vizios-new-true-5-1-soundbar-s4251w/150#post_23741353
Originally Posted by bowlopho /t/1451371/vizios-new-true-5-1-soundbar-s4251w/150#post_23741363
Sorry guys...Wrong thread on the 2.0. I am also in the Samsung thread. Yes, this one is a 5.1 system. However, as mentioned above, only if feed directly and not passed though a TV.
"5.1 Channel Audio Out : Yes"
Yes, if is comes from the internal turner and not being used as a pass through for a blu-ray, dvd, cable box, etc. So yes it can. But not like you think.
Originally Posted by bowlopho /t/1451371/vizios-new-true-5-1-soundbar-s4251w/150#post_23741719
Picked this up today, and loving it. Can someone tell me if the 2 satellite speakers work when bluetoothing music to the soundbar? Bc im only hearing the bar and the woofer while listening to music.
I do get sound from my rear speakers when using my phone hooked up via Bluetooth. I don't know if each input has its own settings that can be adjusted but when playing tunes from my phone the rear speakers are almost too loud compared to the front. play around with the surround setting while using Bluetooth and see if it helps. BTW I really like this system too.
I like the look of this VIZIO 5.1 set-up, but I think I may wait for next years version of it. If it has one. It just needs either HDMI inputs, or multiple optical(2) and Coaxial(2) inputs. Just not enough inputs.
But if VIZIO announces a new one, the price of this will drop for sure. Just need a few more inputs to be worthwhile. I got to "hear" it at Best Buy. Sounded really good. But it did sound a little "muddled/muddy" when compared to the Sony HT-CT260. Even though the Sony is only 2.1, the sound was crisper/cleaner than the Vizio. I would be looking at the HT-CT660 anyway, but that costs about $100-$125 more.
Decisions, decisions, decisions,,,, Buy now, or wait for the new model next year....
helping out my father in law to install these speakers/soundbar he got for his living room. we need the satellite speaker wire to be just a little longer. i'm guessing i can use one of these single RCA audio?
Likely not. Remember the optical 5.1 limitation only applies to those sources sent to the tv via hdmi. This is by design. From what I understand has something to do with license restrictions. A cost most TV makers do not want to pay.
Others correct me if I'm wrong here.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
