Vizio's New True 5.1 Soundbar S4251W - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #1 of 1075 Old 01-11-2013, 10:43 PM - Thread Starter
valley_nomad's Avatar
valley_nomad is offline
post #2 of 1075 Old 03-21-2013, 01:00 PM
Noalkain's Avatar
I might buy this ! Wireless rear speakers !
Noalkain is offline
post #3 of 1075 Old 03-21-2013, 07:13 PM
taichi4's Avatar
Quoted: 330 Post(s)
Liked: 156
I've been waiting for this and its larger brother since CES.
I started a thread on them, but there has been no news in all this time.
Having real rear speakers is better than any emulation, or beamed channels.
taichi4 is offline
post #4 of 1075 Old 03-22-2013, 12:25 PM
Noalkain's Avatar
Do you still have to plug the rear speakers to the sub with it ?
Noalkain is offline
post #5 of 1075 Old 03-22-2013, 12:26 PM
Doctego's Avatar
Liked: 42
If you click the link, you'll see that it says that the rear speakers are wireless.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
post #6 of 1075 Old 03-22-2013, 01:03 PM
Noalkain's Avatar
Yeah I know, but could they mean that you don't have to connect it to the sound bar but it is wired to the subwoofer, which is wireless ?
Noalkain is offline
post #7 of 1075 Old 03-23-2013, 09:53 AM
taichi4's Avatar
Quoted: 330 Post(s)
Liked: 156
I'm pretty sure, from what I've read since CES, that the rear surrounds are wireless, as is the sub...unlike the Vizio 510, which tethers the surrounds to the wireless sub.
As mentioned in the other thread, Philips is introducing a wireless 5.1 soundbar, but at a higher projected price point.
taichi4 is offline
post #8 of 1075 Old 04-09-2013, 07:32 PM
Scopeboy's Avatar
No new soundbar from Vizio, what is taking so long, it's now April 10th??? Disappointed in you Vizio...........
Scopeboy is offline
post #9 of 1075 Old 04-10-2013, 09:45 AM
taichi4's Avatar
Quoted: 330 Post(s)
Liked: 156
I'm impatient as well, but I do believe their new soundbars are coming.
taichi4 is offline
post #10 of 1075 Old 04-10-2013, 03:21 PM
tenashus1's Avatar
Gotta watch out with wireless if you have other sources like an Xbox running. My wireless sub woofer interfered with Xbox live. Had trouble with wireless and my Roku as well. Plus, wireless just adds more RF to your surroundings which is not the healthiest thing already. I've reverted to being a wired guy myself as a result. Old can be better sometimes.
tenashus1 is offline
post #11 of 1075 Old 04-10-2013, 03:51 PM
taichi4's Avatar
Quoted: 330 Post(s)
Liked: 156
Apparently they'll be arriving Late April or early May.
Personally, given that the soundbar is likely to be used mostly with Movies, I'm not concerned about the additional radiation. Wired systems are a lot more complex than an easy to set up Wireless 5.1 Soundbar. They apparently produce low distortion and high ouput.
I'm interested.
aragusa likes this.
taichi4 is offline
post #12 of 1075 Old 04-11-2013, 12:52 PM
Noalkain's Avatar
The satelitte speakers are wireless to the soundbar but not to the subwoofer. frown.gif
http://store.vizio.com/documents/downloads/accessories/S4251W-B4/QSG_S4251WB4.pdf
Vizio also made a webpage fot it, with the mention coming soon : http://store.vizio.com/home-theater-1/s4251wb4.html
Noalkain is offline
post #13 of 1075 Old 04-11-2013, 02:18 PM
taichi4's Avatar
Quoted: 330 Post(s)
Liked: 156
I read that document and you're right! It appears to follow the formula of their last 5.1 Soundbar, the 510, which also has the satellites tethered.
I wonder if the larger version uses the same method.
The forthcoming Philips 5.1 soundbar definitely has completely wireless rears. More money, though.
Interestingly, the Phillips uses a wireless technology that is similar but not identical to Bluetooth, and it appears that there will be less possibility of interference than with a Wifi based system.
taichi4 is offline
post #14 of 1075 Old 04-23-2013, 10:42 AM
Liverpool's Avatar
This Soundbar is now in stock on the Vizio site. I am disappointed to see there is no hdmi arc connection.
Liverpool is offline
post #15 of 1075 Old 04-23-2013, 12:14 PM
RobMueller10's Avatar
Already out of stock.
RobMueller10 is offline
post #16 of 1075 Old 04-23-2013, 12:19 PM
Doctego's Avatar
Liked: 42
You should get the same sound quality using optical.
Doctego is offline
post #17 of 1075 Old 04-26-2013, 06:55 AM
Liverpool's Avatar
Received mine yesterday. The remote does not work. Vizio shipping me a replacement remote not a good start.
post #18 of 1075 Old 04-26-2013, 05:51 PM
How does it sound is the more important question...
post #19 of 1075 Old 04-27-2013, 05:46 PM
sod84's Avatar
Does anyone know if I import this from either the US or Japan (holiday next month), Will the wireless devices be compatible for my use back home in Australia?
any advise would be great.
sod84 is offline
post #20 of 1075 Old 04-28-2013, 04:00 PM
KSUWildcat's Avatar
Strongly considering getting this unit, pending initial reviews and availability. Looks to be a pretty sweet unit that should be easy to set up.
Too bad on the first remote.. hopefully it's not a widespread issue.
KSUWildcat is offline
post #21 of 1075 Old 04-29-2013, 09:37 AM
densin's Avatar
The VIZIO new sound bar Model# S4251W the sat speakers connect to the sub, The Subwoofer is wireless
densin is offline
post #22 of 1075 Old 04-30-2013, 12:28 PM
RealAudiophobe's Avatar
I have my TV on an articulating wall mount.
Can this, or any opthe soundbar, be mounted under (on) the TV itself?
RealAudiophobe is offline
post #23 of 1075 Old 04-30-2013, 05:06 PM
taichi4's Avatar
Quoted: 330 Post(s)
Liked: 156
Many soundbars are mounted on shelves below a TV.
taichi4 is offline
post #24 of 1075 Old 05-01-2013, 02:39 PM
KSUWildcat's Avatar
Back in stock on vizio.com, just fyi
post #25 of 1075 Old 05-01-2013, 05:24 PM
KSUWildcat's Avatar
Also, if anyone is ordering this off Vizio's site, I was able to use coupon code REGVIZIO10 for 10% off the order, which was pretty sweet. Unfortunately, California tax just about brought it back to the full price..
post #26 of 1075 Old 05-01-2013, 05:34 PM
Doctego's Avatar
Liked: 42
Interesting. I just tried to use that code and it didn't work.
Doctego is offline
post #27 of 1075 Old 05-01-2013, 06:04 PM
Worked for me. smile.gif Didnt buy it though. Haha
post #28 of 1075 Old 05-01-2013, 06:59 PM
KSUWildcat's Avatar
Make sure there's no spaces in front or behind the code?
post #29 of 1075 Old 05-05-2013, 02:55 PM
Nubba420's Avatar
Nubba420 is offline
post #30 of 1075 Old 05-06-2013, 07:47 AM
Liverpool's Avatar
I have diagnosed the problem with my remote control intermittently not working is a problem with the soundbar. I have a Vizio tv who's remote also controls the soundbar. When it works both soundbar and tv remote works but somedays the soundbar will not work with either remote proving it is not a remote problem. Vizio are jerking me around on this and are insisting they send a remote. I have lost confidence in the soundbar I have and will press for replacement once I have received remote.
Reply Soundbars
Vizio S4251w B4 5 1 Soundbar
