Jbl sb 400: trouble with Sony blu ray player outputting sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-16-2013, 03:36 AM - Thread Starter
macmd's Avatar
Not sure if anyone has this soundbar. It has 3 hdmi inputs and hdmi out to tv. Connected my Xbox, Apple TV and Sony bluray to soundbar, then connected hdmi out to tv. No prob with sound/video with Xbox and Apple TV, but when I try playing blu ray (ie Ted, sound of music) picture has no prob, but no sound.
Tried switching the consoles to different hdmi connections on soundbar and Xbox/apple tv worked on all inputs but no sound from blu ray on all three connections. Is it because the blu rays are dts hd and according to specs on soundbar state only Dolby digital decoding.
The sound by the way sounds great with good bass and dialog/voices sound crisp and clear. and Bluetooth works great with IPhone playing music.
There are aux input as well as optical input
When I tried playing dark knight rises, I was able to get sound when I went to audio options on disc and chose 2.0 but Ted only gave me the option of dts hd and I was not able to get any sound.
Help, and thanks in advance.
macmd is offline
post #2 of 2 Old 01-16-2013, 07:08 AM
eljaycanuck's Avatar
Quoted: 1229 Post(s)
Liked: 1804
Set your BD player to decode* audio and output LPCM to the soundbar.
(*Hopefully your player can decode lossless (DTS-HD MA / Dolby TrueHD) as well as lossy (DTS / DD) audio.)
eljaycanuck is offline
Reply Soundbars
Jbl Cinema Sb 400 Plug N Play 2 X 60 Watt Soundbar System
