Sony HT-CT150 remote issue with Sony KDL-46XBR4 LCD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-28-2013, 02:57 PM - Thread Starter
tasburath's Avatar
Hey guys,
I just hooked up my HT-CT150.
The HDMI out is going to a Sony KDL-46XBR4 LCD TV.
I have a DircecTV and Panasonic Blur Ray player as inputs.
A couple questions:
Has anyone else figured out how to make the Bravia link work between this model TV and the CT150?
When I turn off the power to the TV with the TV remote, it turns off the power to the CT150. When I turn the power back on to the TV with the TV remote, it does not turn on the CT150 and I have to use the CT150 remote to turn the sound back on.
I may end up just trying to use my direcTV remote for the 3 devices and the CT150 remote for itself.
tasburath is offline
post #2 of 2 Old 01-28-2013, 03:45 PM
Possumgirl's Avatar
Liked: 58
It sounds like BraviaSync is working if the soundbar is turning off with the TV. Not all TVs and/or manufacturers support an "auto-on" function as part of HDMI-CTL. Have you tried turning on the soundbar to see if it will turn on your TV? Check the TV owners manual for HDMI settings to turn that feature ON to see if it works.
Possumgirl is offline
Reply Soundbars
Sony Bravia Xbr Series Kdl 46xbr4 46 Inch 1080p Lcd Hdtv , Sony Sa Wct150 Subwoofer For Ht Ct150
