Samsung HW-450 Soundbar help!!! - AVS Forum | Home Theater Discussions And Reviews
Old 02-05-2013, 03:44 PM - Thread Starter
martinij's Avatar
Hello- Please help!!!
I have a Denon avr-1913 and my cable box, BD, and xbox are all hooked up to the tv with one hdmi wire. Can I hook up my sound bar through the TV or do I have to run it through the denon receiver. Right now I am getting no sound by running it through TV with optical cable.
Thanks so much.
martinij is offline
Old 02-05-2013, 04:00 PM
Possumgirl's Avatar
Liked: 58
Why are you wanting to use a powered soundbar with an AVR? They really aren't meant to go together. That said there are a couple things you could try that may or may not work.
I assume you mean you have your source devices connected to the Denon. Try taking the HDMI output from the Denon and connecting it as input to the soundbar. Then a second HDMI out from the soundbar to your TV.
Or you could try leaving your current connections in place, change the audio output setting on the Denon to "TV", then connect an optical cable from your TV to the soundbar and change your TV speaker setting to "external".
Why didn't you just get speakers or a passive soundbar. You'd likely have much better SQ that way.
Possumgirl is offline
Old 02-05-2013, 04:04 PM - Thread Starter
martinij's Avatar
Yeah I agree on the speakers, but I have a really odd set-up and wiring would be expensive. I think I am out of luck and will have to wire speakers.
martinij is offline
Denon Avr 1913 Receiver
