Recommend a $300 soundbar for simple setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-07-2013, 10:03 PM - Thread Starter
edovp's Avatar
I'm getting a 42" Panasonic plasma TV for my 15' by 20' living room and would like to get a soundbar for better sound. I'm not expecting miracles, just something with some more kick.
WireCutter had me thinking Vizio VHT215 , then I thought maybe a Panasonic would integrate better. I've tried searching, but I think I'm just complicating my search and confusing myself, so I'd like to ask for a recommendation or two.
Here's my criteria:
1. Around $300.
2. I won't have a receiver, just a cable box, AppleTV and maybe an Xbox. I'd like something that's basically plug-and-play and will automatically turn on/off with the TV and switch to the right source without hassle.
3. I don't care if it requires power.
4. I'll probably need a wireless subwoofer.
5. Less than 40" wide would be ideal. I'm working with an in-wall cavity, hence why I'm settling for 42".
Thanks for any help offered and sorry if I left our some vital information.
edovp is offline
post #2 of 3 Old 02-09-2013, 04:33 AM
bigcam406's Avatar
Yamaha YAS101 will be perfect for your needs.i have one hooked up to a 42'' LG lcd,same size room and the Yamaha rocks it.nice clear sound,good bass,though not overbearing,this soundbar is a good bang for the buck.
bigcam406 is offline
post #3 of 3 Old 02-13-2013, 01:52 AM
orijin's Avatar
I will recommend to you the SONY HTCT260 amazing sound, listen to it all the time as I recommended that one to my roommate and he got it. Sounds amazing with music and great with movies too.
And wireless subwoofer to meet you needs!
Currently Using:
SONY 55HX750
LG 55LM7600
B&W Panorama 1
orijin is offline
Reply Soundbars
Vizio Vht215 , Sony Htct260 Sound Bar Home Theater System
