Using TV Remote for Volume Control w/ New Soundbar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-11-2013, 10:59 PM - Thread Starter
The3rdM's Avatar
I have the 51' E550 Samsung Plasma HDTV. I just purchased the LG 300w 2.1 Soundbar with Wireless Subwoofer.
Is it possible to control the volume with my TV remote?
The3rdM is offline
post #2 of 2 Old 02-13-2013, 03:57 AM
inglorius 1's Avatar
I think Samsung has a setting called AYNET+ which is similar to the SIMPLINK setting for LG devices which lets you control all linked devices with a single remote..I'm not sure where you find the AYNET setting as i have both an LG tv and soundbar, but I know you can link these 2 settings to each other..check your sound bar manual for how to set your sound bar to link with a Samsung tv as there are different codes for different makes
Hope this helps
inglorius 1 is offline
Reply Soundbars
