Soundbar recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-24-2013, 02:32 PM - Thread Starter
cgott42's Avatar
Quoted: 155 Post(s)
I currently have a set of Klipsch reference speakers RF82 II ,64 II , 62II snd an SVS sub with a denon 2809ci AVR
Unfortunatley I didn't plan correctly and the speakers - although great, block part of the screen.
I'm toying with the idea of replaicng them and considerint the options.
I read an article on Goldenear soundbar andhow it's almost a regular speaker replacement.
My room is about 10 x22
Is there any soundbars whcih would give me the same experience.
Also - in terms of wiring - I have my HT setup with a separate equip room, and theo speaker wires coming out of the wwalls in the theater room in the regular spots. Would using a soundbar require rewiring (=problem?)
thx
cgott42 is offline
post #2 of 9 Old 02-24-2013, 04:39 PM
BobL's Avatar
Liked: 58
If you are looking for an LCR soundbar there are many good choices and uses standard speaker wiring. It is like having all three speakers in one unit and depending on where your wiring is run it might be the easiest solution for you. You would still use your receiver, surround speakers and subwoofer.
If you are looking for a surround bar that gives a surround sound effect and will replace your current system then different wiring will be required. It depends on which soundbar you are considering on how it would be connected.
BobL is offline
post #3 of 9 Old 02-24-2013, 05:00 PM - Thread Starter
cgott42's Avatar
Quoted: 155 Post(s)
What is an LCR soundbar?
I'm looking for something to give the full surround sound effect for movies.
cgott42 is offline
post #4 of 9 Old 02-24-2013, 08:11 PM
mr51's Avatar
thx
Although I'm not a expert on the subject of soundbars, I think the simple answer to your question is NO. A soundbar will not give you the same experience as a 5.1 or 7.1 system.
mr51 is offline
post #5 of 9 Old 02-24-2013, 09:14 PM
kat
kat's Avatar
LCR = Left, Center, Right.
The LCR soundbar directly replaces these speakers in a surround setup. You'd still need rears and sub, for instance.
kat is offline
post #6 of 9 Old 02-25-2013, 05:51 AM - Thread Starter
cgott42's Avatar
Quoted: 155 Post(s)
Yep, I'm looking for LCR
cgott42 is offline
post #7 of 9 Old 02-25-2013, 06:20 AM
BobL's Avatar
Liked: 58
There are many good brands but if you are going to use with your current surrounds I'd use the Klipsch soundbar to better match with what you already have.
http://www.klipsch.com/gallery-g-42-soundbar
BobL is offline
post #8 of 9 Old 02-25-2013, 07:10 AM - Thread Starter
cgott42's Avatar
Quoted: 155 Post(s)
thanks - how much will the drop off in performance beg between this and my current loudspeakers - (b/c I paid a lot more than this for my loudspeakers)
I want to make sure there's not a significant drop off. If necessary - I could replace my surrounds too.
cgott42 is offline
post #9 of 9 Old 02-25-2013, 02:49 PM
BobL's Avatar
Liked: 58
There is no doubt there will be a performance difference between towers and a sound bar. LCR Sound bars are like regular speakers, just three small speakers placed close together. Most sound bars don't have anything bigger than 4" woofers. You are not going to get the same type of impact with smaller speakers. Also, with sound bars having the left and right only a few feet apart is not going to be as good with speakers you can place in better locations and a little further apart for a good soundstage. Soundbars fit a need where placement is difficult and/ or aesthetics play a big role. They give better sound than a TV and can be very enjoyable but don't expect them to compete with a larger well set up system.
If towers or decent bookshelves on stands are not possible you might consider larger in-wall or on-wall front speakers if that will work for your situation. It won't look as nice as a sound bar but will perform better.
Having said that I haven't heard the Klipsch or Golden Ear sound bars. I like Triad which can be custom sized to match your TV's width and if you have a larger TV it gets the speakers a little further apart, Atlantic Technology and Episode also make good sounding speaker bars. Other good brands are Leon, James Loudspeaker and Paradigm. Leon also does custom sizing. There are many good brands and I'm sure you'll get a lot of recommendations.
BobL is offline
Reply Soundbars
Denon Avr 2809ci 7 1 Channel Multizone Home Theater Receiver
