DirecTV remote to control Martinlogan soundbar problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-25-2013, 09:47 AM - Thread Starter
MitNagrom's Avatar
I go through the "learn" steps to program my directv remote to control the up/down volume and mute on my sound bar. I folllow the steps exactly and get no errors. However, all three buttons (up volume, down volume and mute) work to increase the volume. The mute and down volume do not do what they are supposed to do. They all just increase the volume no matter which of the three buttons I use.
Any advice? Thanks!
MitNagrom is offline
post #2 of 2 Old 02-27-2013, 01:25 PM
DetroitSlim's Avatar
I had the same problem. I solved it by programing my DirecTV remote to work with my TV. I then used my TV remote to program the volume up, volume down and mute on the soundbar. Finally I used the DirecTV remote to program the power on and power off on the soundbar. When I was done the DirecTV remote was able to control all five functions.
DetroitSlim is offline
Reply Soundbars
