Home Audio Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-27-2013, 04:15 AM - Thread Starter
Steven Weeks's Avatar
Hello, I just purchased a Panasonic P55ST50 Plasma TV and Klipsch SB 3 Sound bar. After spending a good chunk of change for these two items I would like to setup all my devices correctly. The TV has 3hdmi inputs and an Optical. The sound bar only has RCA cable outputs and an Optical (NO HDMI). I also have a HDMI cable box and HDMI PS3 to connect. Would someone please be able to tell me if connecting the PS3 and Cable box to the TV via HDMI and then the Sound bar to the TV via Optical is the best way to connect this? or how should I setup to get optimum sound? I'm confused because the cable box and PS3 also have optical as well.
Thank you so much
Steven Weeks is offline
post #2 of 13 Old 02-27-2013, 04:44 AM
Bond 007's Avatar
Quoted: 2371 Post(s)
Liked: 1907
If the soundbar has only 1 optical port then you dont have any choice, do you?
Licence to Kill
Bond 007 is online now
post #3 of 13 Old 02-27-2013, 05:43 AM - Thread Starter
I heard of something called an optical splitter. Would that help? Would current setup sound bad?
post #4 of 13 Old 02-27-2013, 06:08 AM
Doctego's Avatar
Liked: 42
You can get something like this:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=2946&seq=1&format=2
Ideally, I would want to get a soundbar with HDMI input(s). If that wasn't possible, I would get the switch above. You can first hear how it sounds outputting the TV only via optical. If that's good enough, just go with that.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
post #5 of 13 Old 02-27-2013, 10:54 AM - Thread Starter
Ok thanks. If I did get a sound bar with hdmi wouldn't it need to be turned to that hdmi channel in order to hear from it? Sorry just confused with different ports and functions.
post #6 of 13 Old 02-27-2013, 11:02 AM
Bond 007's Avatar
Liked: 1907
How much did you pay for the soundbar?
Licence to Kill
post #7 of 13 Old 02-27-2013, 11:30 AM
Bond 007's Avatar
Liked: 1907
post #8 of 13 Old 02-27-2013, 11:36 AM - Thread Starter
If this helps the klipsch sb 3 has a built in Dolby digital decoder. What is that?
post #9 of 13 Old 02-27-2013, 11:37 AM - Thread Starter
$800
post #10 of 13 Old 02-27-2013, 11:39 AM - Thread Starter
post #11 of 13 Old 02-27-2013, 11:41 AM
Bond 007's Avatar
Liked: 1907
That doesnt help. It means that it will decode Dolby Digital. Means nothing really in terms of a soundbar. You are not going to get 5.1 surround sound. And you will also not get lossless sound (Dolby True HD and Dolby DTS Master Audio). You will get all of that with the setup that I suggested. What are your thoughts on that?
Licence to Kill
post #12 of 13 Old 02-27-2013, 12:02 PM
Bond 007's Avatar
Liked: 1907
post #13 of 13 Old 02-27-2013, 04:35 PM
Doctego's Avatar
Liked: 42
I'm not following. If you got a soundbar with HDMI inputs, you could connect the sources to the soundbar via HDMI and then output the soundbar to the TV via HDMI. That is my preferred method of connection.
I would recommend trying some different connections out. Try connecting the TV to the soundbar via optical. Then, try out your different sources and see how they sound. Next, try connecting your various sources to the soundbar via optical individually (while keeping the HDMI connections to the TV for video). See how that sounds relative to the optical connected from the TV to the soundbar. This is assuming that your sources have an optical connection. If this method sounds better, you can buy the switch that I posted above.
Of course, you can always get another soundbar with HDMI inputs and scrap what I just wrote.
Doctego is offline
Reply Soundbars
