hooking up my Vizio Soundbar 215 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-03-2013, 05:17 PM - Thread Starter
shadesofalan's Avatar
OK so I buy the Vizio Sound bar 215 to go with my Samsung 55" 6000 series TV problem I also use WD TV Plus for playing my movies through and eventually use as the main media center. Problem Samsung has only (2) HDMI connections which are being used by satellite provider box and WD TV Plus so cant use HDMI for the sound bar will the digital optical be fine from TV to sound bar and if so which manufacturer should I by. Thought of doing the HDMI amplifier thingy with (2) output HDMI and (1) input but figure might be a problem so digital optical should work fine and get good quality sound ....any input appreciated....thanks in advance.cool.gif
shadesofalan is offline
post #2 of 5 Old 03-03-2013, 06:09 PM
Possumgirl's Avatar
Liked: 58
Your BEST connection option is connect both the sat box and WD TV directly to the soundbar via HDMI, then another HDMI from soundbar to TV.
Although you can leave your source devices connected to the TV and run an optical cable, be aware that most HDTVs only output 2 ch. stereo except from their internal tuners.
Possumgirl is offline
post #3 of 5 Old 03-04-2013, 04:31 AM - Thread Starter
Thank you Possumgirl unaware that I could do it that way makes sense since (3) HDMI connectors on the sound bar one being ARC appreciate that will do let you know the outcome smile.gif
post #4 of 5 Old 03-05-2013, 08:29 PM - Thread Starter
Possumgirl it worked out just fine thanks for you most informative post:p
post #5 of 5 Old 03-27-2014, 09:08 PM
boykillsworld's Avatar
Just for future notice this soundbar is a 2.1 so you loose nothing feeding it 2 channel only. I agree though stick to HDMI whenever possible. I did not test how well the optical sounded but I imagine it would be exactly the same.
boykillsworld is offline
Reply Soundbars
Vizio Vht215
