help with ysp-2200 yamaha - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-12-2013, 09:20 PM - Thread Starter
perferd's Avatar
So I just got everything set up did the auto tune and started the options in rain and thunder. My problem is in the options it says the audio setting is supposed to read dolby d on the display but mine says pcm. While listening to the track it sounds like I am only getting 2.1 instead of 5.1 btw I have my ps3 hooked to the ysp via hdmi then the ysp hooked to the tv via hdmi in the arc slot and the yellow video cable from ysp to the tv into video 1...
Help would be appreciated thanks...
perferd is offline
post #2 of 3 Old 03-12-2013, 10:05 PM - Thread Starter
perferd's Avatar
Ok I figured it out...
I hear a diff during the demo but I don't necessarily hear things from behind me like rear channels...
When talking to the guy he said when he heard the demo he could actually manually move the sound back and forth from what I would assume he meant was a specific driver???
perferd is offline
post #3 of 3 Old 03-14-2013, 12:26 PM
fotonomad's Avatar
Liked: 0
I have the YSP2200 as well. All set up and sounds great. Does anyone know how to dim the display lighting? This function is mentioned in the manual, but the instructions are not clear, re: what buttons to push on the remote, exactly how to access this setting option via some obscure sub- menu, etc. Maybe I'm missing something obvious, but I can't locate it. The standard (default) display level is too bright - really distracting when watching a move in a dimly lit room. Any help is appreciated!
fotonomad is offline
Reply Soundbars
Yamaha Ysp 2200 Digital Sound Projector Black
