Using TV Optical Out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-16-2013, 03:16 PM - Thread Starter
ncochran01's Avatar
I'm in a bit of a pickle here.....
I have an LG soundbar (having problems finding the model) that has my Xbox and Tivo connected to it.
Shortly, I'll be switching to recording TV on my PC and using my Xbox as an extender. This will free up a connection on my soundbar.
This is my problem, I found a cheap Blu-Ray player on Woot!. It has everything I want, Blu-Ray playback, Netflix, Hulu, Youtube, VuDu and others (instead of paying for a Microsoft Live account), but it doesn't have optical out. My soundbar doesn't have HDMI, only optical.
So I'm wondering, my Blu-Ray player will be connected to my TV via HDMI. My TV has an optical out. If I use the optical out from the TV to the soundbar, how ****** will it sound? Will it just send the HDMI signal out through the optical port on the TV, or will my TV process it and send it to the soundbar.
ncochran01 is offline
post #2 of 6 Old 03-16-2013, 03:50 PM
Possumgirl's Avatar
Liked: 58
There's a 99% chance the BD player will downmix to 2ch. stereo if it's connected to the TV. Please post the make/model# of the BD player so we can see if there are other options. It would be real helpful to have the model # of the LG soundbar too.
Possumgirl is offline
post #3 of 6 Old 03-18-2013, 11:48 AM
orijin's Avatar
Seeing that you are using the tv for optical playback its more than likely you will get the downmix. If you are using a bd player that has optical out you will probably get the DTS and DOLBY signals, my current panorama with tv optical uses downmix while my panorama with the 2nd optical out to the ps3 will do dts and dolby.
Currently Using:
SONY 55HX750
LG 55LM7600
B&W Panorama 1
orijin is offline
post #4 of 6 Old 03-18-2013, 07:20 PM - Thread Starter
ncochran01's Avatar
The BD player is: Sony BDP-S185 Internet Ready Blu-ray Player
Inputs and Outputs
HDMI Output(s) : 1 (Rear)
Composite Video Output(s) : 1 (Rear)
USB Input(s) : 1 (Front)
Analog Audio 2ch Output(s) : 1 (Rear)
Digital Audio Output(s) : 1 (Rear)
Ethernet Connection(s) : 1 (Rear)
Soundbar: LG NB3510A Soundbar with Wireless Subwoofer and Bluetooth Connectivity
AV INPUTS/OUTPUTS
Portable Audio Input: 1
Optical Digital Audio In: 2
Subwoofer Output: Wireless Subwoofer
post #5 of 6 Old 03-19-2013, 09:46 AM
Possumgirl's Avatar
Liked: 58
The BD player has digital audio out, it just happens to be coax instead of optical. You need a converter like this one (and the necessary cables) to connect the player to one of the optical inputs on the soundbar. In other words....no problem! biggrin.gif
ncochran01 likes this.
post #6 of 6 Old 03-20-2013, 04:35 AM - Thread Starter
ncochran01's Avatar
That's good news. I ordered this:
Coaxial (RCA) to Optical Toslink Digital Audio Converter
6ft High-quality Coaxial Audio/Video RCA CL2 Rated Cable - RG6/U 75ohm (for S/PDIF, Digital Coax, Subwoofer & Composite Video)
6ft Optical Toslink 5.0mm OD Audio Cable
Reply Soundbars
Sony Bdp S185 Blu Ray Disc Player
