Sharp HT-SB60 Sound Bar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 03-23-2013, 12:01 AM - Thread Starter
SharpCat's Avatar
Saw and heard the Sharp SB60 Sound Bar at CES 2013 … and just had to have one.
Like most products at CES you have to wait till Spring before they ship.
Finally found mine at Beach Audio, $367 free shipping.
Sharp claims the SB60 is made for 60" and larger screens, and indeed it's a perfect match for my 70".
Sounds bigger than than the TV screen itself.
What more is there to say … OK ... I will elaborate just a little.
First off this thing shows up in a big ass box, no worries whats inside is very manageable.
The Sound Bar measures 54" long by 2.75" tall ... wireless Sub 17" tall X 5" wide.
Cosmetics match up perfectly with my Sharp LC-70LE6400U, or any current Sharp HDTV for that matter. Brushed metal look with a LED display in the middle. There is no grill cloth cover for the Sound Bar's exposed drivers, personally I like that, a real 1" soft dome tweeter and two 2" midrange drivers per channel. This is a 2.1 channel speaker system, 50 watts RMS per Channel, 110 watts RMS for the sub. That's Beefy for a SB my friends, trust me it gets plenty loud.
As always I tossed the instruction booklet aside and proceeded to hook this bad boy up. Plugged the Sub and SB into the wall, hooked the supplied HDMI cable to "input 1" on the HDTV & HDMI "out" on the SB. Pressed the ARC (Audio Return Channel) button on the upper left of the supplied remote and music erupted from the system. Yes, that's what I'm talking about, a Sound Bar that don't take and engineering degree to turn on.
The owners manual goes on and on but that's all it takes to work, well you do have to have "AQUOS Link" ARC turned on in the System Options Menu on your TV. Other brands call this feature other names. http://hdmicec.blogspot.com/2012/05/how-to-find-out-if-your-device-is-hdmi.html I'm sure the SB60 will be equally at home with other brand HDTV's. Worst case scenario you can use the fiber optic or mini jack.
I have a Pioneer BluRay player, DirecTv Tivo, and Apple TV hooked to HDMI input 2,3,4 on my Sharp 70". Audio feeds naturally from all 3 source devices though the Audio Return Channel on HDMI input 1 to the Sound Bar. I can control volume with either the DTV Tivo or Sharp TV remote so I packed the SB remote away after I made some minor adjustments. The sub automatically sets itself up wirelessly with zero drama, a little blue light appears on the front when it's connected. From the seated position all the bass appears to come from the Sound Bar. I found the best soundstage with the Sound Bar mounted above the HDTV, brackets included. Voices appears to come directly from the characters on the TV. Very Impressive. You adjust the sub volume on the remote, then tweak a little bass and treble (I used +2, +2) and your done. Sit back and enjoy.
HOWS THE SOUND QUALITY YOU ASK?
In one word, EXCELLENT!
SharpCat is offline
post #2 of 35 Old 03-24-2013, 10:57 PM - Thread Starter
SharpCat's Avatar
A couple of pictures of my A/V setup, my new Sharp HDTV now lives where my old 60" Sony XBR800 used to sit. Had to go with a 70" just to fill the vacated space of the old Sony LCD rear projection. That left a 4" gap at the top of my custom wall unit. As you can see I filled that space with the new large format Sharp HT-SB60 Sound Bar. The picture and sound I get from this dynamic duo is down right shocking. I paid $4K for the Sony XBR back in 2002, and $1350 last week for the display model Sharp 70LE6400 at Costco.
Price/value to performance in today's world is simply off the charts.
I am amazed how sharp (no pun intended) the picture looks with the new Super HD downloads from Netflix, the look and feel is so different looking … it's almost freaky. I live in Phoenix and Cox Cable just started working with Netflix to provide the service, nearly half the programs I watch are available for download in 1080p 24fps SuperHD. I must have been living under a rock because I never even heard of Netflix Super HD until last week. This put the $8 monthly Netflix subscription value also off the charts.
Even though I went to CES 2013 and saw for myself the new 4K & OLED monitors, I never imagined that this sort of quality HD programming would be available for years to come. What a pleasant surprise for this perfect storm to materialize at my house this week. For those of you who haven't seen anything but 1080i being manipulated by HDTV software … you're in for a treat!
I "downloaded" The Hobbit from DirectTV HD Cinema just to verify that it's 1080p 24fps that's responsible for making this "freaky deaky dutch" picture. Cost me $5.99 for just one movie, but yes, it provided the same mind-blowing resolution. My evil eye now turned to my Pioneer BDP-430 BluRay … what's up with this turd. My bad, forgot to change the output of the Bluray to 1080P.
This 1080p 24fms thing is like doing drugs, I guess you could call this format 2K video. Ggoing back to regular 1080i programming is almost disappointing. This has me thinking I need to feed my new HDTV with a steady diet of 1080p 24 with one of those new DVDO Edge Green scalers.
http://www.amazon.com/DVDO-High-Definition-Processor-Connectivity-Solution/dp/B001OOZU8I/ref=sr_1_1?s=electronics&ie=UTF8&qid=1364185352&sr=1-1&keywords=dvdo+edge
I can't eye … 1080i ...
Getting back to the sound of the Sharp SB60 sound bar, it's just stupid how good this thing sounds for the money.
As you can see in the picture above I have a full blown 9.1 surround system at my disposal. I even run front height speakers (an old pair of Bose 901 perform that duty) to lift the voice up from the center floor speaker when I pull down my 126" projector screen. While my surround system will run circles around the SB-60, I find myself watching my new 70" Sharp 90% of the time. I actually find no pressing need to turn on the main surround system, thats how good the SB-60 is. If fact I now find the main surround system a bit subtractive in nature when watching anything but movies.
Enough said.
caddyman likes this.
SharpCat is offline
post #3 of 35 Old 06-04-2013, 05:19 AM - Thread Starter
SharpCat's Avatar
I have to offer full disclosure on my on-going problem with my Sharp SB60 sound bar.
After 30 days of perfect operation my first SB60 Sound Bar failed to turn on.
Called Sharp and tried to unplug and perform a hard reset of both the TV and sound bar. No help, the SB60 was dead.
Sharp's suggestion was to mail it to their national repair center, at my cost, and if they determine its defective, repair or replace it.
Really! I no longer had the original packaging and this would be a total pain in the butt.
Contacted Beach Audio where I purchased the SB60, and while I was out of their 30 day return policy, they were kind enough to send me a free UPS return label via email. To speed things up I simply purchased a new SB60 from Beach and I shipped the original sound bar back in that box.
Ok so how did the new replacement SB60 sound bar fare …. not good!
My Sharp LE6400U TV continuously lost contact with the SB60 sound bar though the HDMI ARC (Audio Return Channel)
The only way to get it to work again was to do a factory reset of the TV.
Within 2 weeks I was lucky to get 1 hour of sound before it kicked back to the internal speakers.
Thinking perhaps it was a problem with my LE6400U TV, I returned the TV back to Costco after 86 days and purchased the 2013 model LC-70LE657U. The good news is the LE657U is superior in every way. 10 times the Apps … with 10 times the speed, Web browser controllable with my bluetooth keyboard, iPhone app to replace the remote control, the list goes on and on. Love the HD Skype and Netflix SuperHD. Picture is clearly better than last years model, 3D is a bonus. (Comes with 2 pairs of bluetooth 3D glasses) Less edge bleed, deeper blacks, sharper picture. You be hard pressed to find a better price to value in a 2013 HDTV.
The bad news is the replacement SB60 sound bar still looses connection with the new TV on the ARC.
Called Sharp and once again got the runaround, did get one rep to admit they where having a firmware issue with the first run of SB60 sound bars. (I would have to return it to them to get the firmware updated.) Really, the thing doesn't even work with your own TV's! So yes this turkey is also going back to Beach Audio, such a shame as the SB60 looked nice and sounded awesome.
Will I wait a few months to make sure I get an SB60 with updated firmware ... I don't know.
What I do know is I hooked the TV HDMI ARC to my Pioneer receiver and LE657U has no connection problems with it. The TV remote turns on the big Pioneer and even runs the volume up and down on the receiver. Even found out the Sharp TV Remote will run my Pioneer Bluray player through the ARC. My wife has already adapted to having the surround sound on all the time now that I also programmed the DirecTV Tivo to run the receiver volume.
The only downside is how much extra power we burn running the Pioneer receiver all the time. Doing the match I figure it will cost us an extra $10 month for electricity. With the refund of the $360 for the sound bar, it will take us 36 months to break even.
By then the 4K TV's will be out ………………………………...
SharpCat is offline
post #4 of 35 Old 06-21-2013, 05:15 AM
caddyman's Avatar
I have one of these soundbars also. Beautiful sound......when it worked.Which it did for about 6 months then whilst watching wrestling it died.I did the unplug for 10 minutes, did a hard reset......nothing got it working. I called Sharp and was told by the rep if I faxed them a copy of the receipt then they would email me an RMA label!!! Obviously i didn't keep the receipt that long but I did still have the original packaging (for some reason my gf likes keeping boxes) I went on a mission to find the receipt to no avail. Was about to give up when lo and behold Sharp decided to send me the RMA label anyway. So I boxed it up in the original box and it should arrive today at the repair center. Whether they fix it or give me a new one I'm not sure but I'll post back with the results.
caddyman is offline
post #5 of 35 Old 06-22-2013, 09:16 AM
caddyman's Avatar
Well I got the email stating that the sound bar arrived at their repair facility yester day at about 10 am central time. About noon i got the email that it has left the facility on its way back repaired!! Whether its the same on or a different on I'm not sure but that sure was fast!!!
caddyman is offline
post #6 of 35 Old 06-22-2013, 02:02 PM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
I have the same HDMI ARC issues with mine. Not a big deal to me as I really don't use ARC but hoping it last longer than a few months.
almostinsane is offline
post #7 of 35 Old 06-23-2013, 10:00 AM - Thread Starter
SharpCat's Avatar
I was told by a Sharp repair technician it's nothing more than a flash of the firmware that fixes the ARC disconnect problem, and no it can't be done at home.
My first SB-60 failed completely, one day it just stopped working. Just dead, would not turn on at all.
The replacement SB-60 was shipped new in the box and it developed the ARC disconnect issue right at 30 days.
It will be interesting if they just flash your firmware and send back your original SB-60.
Do you have S/N on the unit you sent back?
I really liked the SB-60 but it looks like they have software issues with the first batch.
Keep us updated, I may take another swing at the big sound bar if they work out the bugs.
SharpCat is offline
post #8 of 35 Old 06-23-2013, 06:01 PM
caddyman's Avatar
I'll def keep y'all updated. I had to look thru my emails (hasn't been a good tech week for me) but no I don't have the serial number written down but I do have a unique way of recognizing it.
caddyman is offline
post #9 of 35 Old 06-25-2013, 07:29 PM
caddyman's Avatar
Well I got the soundbar back yesterdaay. So far so good as a matter of fact it actually sounds better than it did so it most likely had something else wrong with it. It is the same one I sent. I know by the paw prints on top of it. In the email I got from Sharp saying that it was on its way back to me there was a link supposedly leading to the details of the repair. But when I clicked it was taken to a page saying "repair not found". I sent Sharp an email asking exactly what was repaired. The reply was fairly vague......see their reply below.
caddyman is offline
post #10 of 35 Old 06-25-2013, 09:25 PM
Quoted: 47 Post(s)
Liked: 42
This thing is garbage. Going back to Amazon and getting something else.
post #11 of 35 Old 06-25-2013, 10:37 PM
caddyman's Avatar
I take it your stopped working too??
caddyman is offline
post #12 of 35 Old 06-26-2013, 09:20 PM
Quoted: 47 Post(s)
Liked: 42
It works with the remote but CEC stopped working and there is a faint hiss from the speakers at low volume.
I'd like to replace it with something else but I'm not sure what. The Yamaha seem to suffer from lip sync issues, won't touch Sonos as they don't have HDMI.
What I really want is something that decodes all HD formats, has 2-3 HDMI inputs, Bluetooth, and CEC integration.
post #13 of 35 Old 12-29-2013, 05:36 PM
Hcables's Avatar
I wired my sound bar the way you posted. I have the hdmi arc on my tv and wired that into the hdmi On the sound bar. When it works I love the sound. The only thing is, it will only power on if I unplug it from the wall and plug it back in. If I shut the tv off the soundbar goes off and will not turn on unless I unplug and rep lug back in,. Any help you can give would be appreciated. Thanks
Hcables is offline
post #14 of 35 Old 12-30-2013, 09:55 AM
Qualityair's Avatar
Mine is wired as per instructions to my sharp 80 inch television and works perfectly
Qualityair is offline
post #15 of 35 Old 01-18-2014, 01:01 PM
Baron Blood's Avatar
Quoted: 60 Post(s)
I was seriously considering this bar until I came across this thread.
I'm amazed with all the glowing reviews online that this thread is all there is here.
Does anyone still recommend to stay away?
Baron Blood is offline
post #16 of 35 Old 01-19-2014, 08:03 AM
Qualityair's Avatar
Mine is still working fine, its on a 80-857 TV.
post #17 of 35 Old 02-04-2014, 01:55 PM
Samand's Avatar
Can you tell me what manufacturer your mini display to HDMI adapter is.
I have had some issues with mine.
Samand is offline
post #18 of 35 Old 03-07-2014, 06:20 AM
fiscomi's Avatar
How is every ones working after the fix? I'm debating on getting one of these things.
fiscomi is offline
post #19 of 35 Old 04-03-2014, 03:11 PM
0000200715's Avatar
I just got the bar when I plugged it in a hissing computer sound can be heard coming from it? Very annoying is this normal?
0000200715 is offline
post #20 of 35 Old 10-11-2014, 12:18 PM
Liked: 0
Hey guys
I wish I saw your comments before I bought mine. I also have the same issues. Mine has been buggy all along, losing connection to TV, to subwoofer. Then is stopped working after 13 months. Not ever considering Sharp again. I shoulda bought Bose at Frys when I had the chance...
Uhappy Dave is offline
post #21 of 35 Old 10-11-2014, 04:53 PM - Thread Starter
SharpCat's Avatar
Sharp HT-SB602 Soundbar
Sharp quietly snuck out an upgraded model this summer cleverly called the HT-SB602 Sound Bar.
Identical to the SB60 except for Bluetooth input, black colored drivers, and the fact that it now ... actually works!
I decided to give the new SB-602 sound bar a shot with my new Sharp LC-70SQ15U TV. (4K Ready)
Three months and 'so far so good' with both the Sound Bar and HDTV. No connections issues, no issues what-so-ever, same fantastic sound. However the picture just blows away my old LC-70LE6400U HDTV, tried several custom settings but now pretty much leave it on a custom Dynamic mode, dot by dot.
I was able to to get a fantastic deal on both the HDTV & Soundbar and can highly recommend both products. This time I purchased the Sharp 3 year warranty on both items. That's 3 years on top of the 1 year factory warranty. 4 years total, $150, Nice!
I suspect the 70SQ15U will be a short-lived product as Sharp has already announced replacement models, no doubt with built in HEVC or H265 for 4K via Netflix & other web apps. The 70SQ15U can only do 'quasi' 4K via a HDMI input, I'm waiting for the Apple TV 4 which will feature H265 and be my 4K App delivery device. For now I downloaded a 4K feature on my MacBook and used WonderShare Ultimate to get a peak at my first 4K video ... I have to tell you the picture is just awesome.
I bring this all as the 70SQ15U will no doubt be on close out during Black Friday.
Perhaps some of you can snag a smokin' deal on the "near 4K" Sharp LC-70SQ15U.
You can already buy it on Amazon for $1900.
http://hdguru.com/q-a-with-sharp-on-...q-series-tech/
SharpCat is offline
post #22 of 35 Old 11-24-2014, 09:32 AM
jbeechuk's Avatar
The SB602 is on sale for $200 at BB right now. Half off!
jbeechuk is offline
post #23 of 35 Old 11-27-2014, 07:28 PM
JackB's Avatar
Quoted: 478 Post(s)
Liked: 76
Bought a 602 at BB for the $200 deal. Works well so far. Hooked right up with 2 hdmi cables from BR player and Directv DVR to HDMI in. HDMI out to Vizio P70 flat panel with ARC. Perfect! Got my fingers crossed.
Jack
JackB is online now
post #24 of 35 Old 11-28-2014, 11:21 PM
jbeechuk's Avatar
I also got the 602 from BB for $200. Half off was too good to pass up. Easy to hook up. Much better bass than I expected. Sound good...but not outstanding. I know there are better sounding sound bars, but I needed one that was low profile and super wide.
jbeechuk is offline
post #25 of 35 Old 11-28-2014, 11:34 PM
Liked: 0
what prices on amazon guys? .thanks
bangdane is offline
post #26 of 35 Old 01-02-2015, 04:26 PM
gm2376's Avatar
Quoted: 20 Post(s)
Can someone please tell me how to hook up the 602!!!! I have a sharp of lc70ud27 tv and sb 602. I have my cable in hdmi1 in the bar and Xbox 1 going to to hdm1 2 in the bar. I have the hdmi out going to hdmi 1 in the tv. Hdmi 1 is the arc input. I have my harmony set to pick the out put tv arc on the sound bar. When tv arc is selected,i get no pic or sound. I have to select the hdmi out put on the bar to get a pic. Doesn't that defeat the purpose.arc is enabled on the tv. Is something wrong. I'm going crazy.
gm2376 is offline
post #27 of 35 Old 01-02-2015, 05:24 PM - Thread Starter
SharpCat's Avatar
Here are the setting on my Sharp 70" HDTV to work correctly with the SB 602 ... go to:
SETUP
Advanced
AQUOS LINK Setup
AQUOS LINK Control (ON)
Auto Power On (Yes)
Audio Return Channel (Auto)
Channel Select Key (ON for HDMI 1 & HDMI 3)
The Sound Bar "HDMI output" is hooked to HDMI 1 on the TV (also my ARC).
I have a Pioneer BluRay (made by Sharp) hooked to HDMI 3, the above setup also allows me to control the BluRay player from the TV remote ... and auto on trigger plus volume control on my SB 602 sound bar.
Hope this helps.
SharpCat is offline
post #28 of 35 Old 01-02-2015, 06:14 PM
gm2376's Avatar
Quoted: 20 Post(s)
SETUP
Advanced
AQUOS LINK Setup
Auto Power On (Yes)
Hope this helps.
Does the sound bar have to be in standby? It only seems to work sometimes when set to standby, never in eco mode.
gm2376 is offline
post #29 of 35 Old 01-03-2015, 12:17 AM - Thread Starter
SharpCat's Avatar
Yes mine goes to "standby" when its off ... I never even knew there was an "eco" mode.
I sometimes have trouble waking the sound bar from standby if the volume is set to low, hit the volume up button on the tv remote and it pops on.
I have had my SB602 for 6 months now ... no issues!
SharpCat is offline
post #30 of 35 Old 01-04-2015, 09:19 AM
Liked: 0
not so good results with SB-602
Alright, I came across this thread a while back (6-7 months ago) but decided to buy the original (no bluetooth) 60" soundbar and ended up having the same issue as everyone else. I called Sharp, maybe 12 times, and got the run around telling me to unplug this and power cycle that. I took to Sharp's Facebook page and immediately got a call from a "real" sharp rep (not just someone reading troubleshooting tips off of a computer screen) and they instructed me to mail my sound bar back on their dime. I mailed my soundbar back to sharp, about a week later I got it back stating that they had swapped out the main board in the bar. Well that worked fine for a month or two and then the same problem. This time I called sharp and demanded they give me then "new" SB 602. They did, and it worked fine for a few months, and now I'm at the same point I was at before. The tv arc doesn't work at all, which is especially annoying if I'm trying to watch anything other than my Directv. I don't get any sound using a USB stick with a movie on it, no sound if I run my laptop into HDMI 2, the only way it works is if it goes through the soundbar and then into my tv. I have the HDMI 1 (tvarc) on the TV running to the HDMI out on my soundbar. Also, made sure that I'm using the latest HDMI version of cord.... I have the extended protection plan on my TV from best buy, so I have geeksquad coming out on saturday to swap the main board...they claim that will fix it. We'll see...
tonyd9448 is offline
Reply Soundbars
Sharp Ht Sb60 High Powered Soundbar System For 60 Inch Larger Tvs With Wireless Subwoofer
