Soundbar that can replace my receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-31-2013, 11:41 AM - Thread Starter
Nutdotnet's Avatar
Quoted: 110 Post(s)
Liked: 41
Howdy!
We're turning my "man" room into our master bedroom (another story all together). I'm going to be replacing my 5.1 separates with a soundbar (yet again another story). Due to space constraints, I'm wondering if there are soundbars out there that can effectively replace my Onkyo receiver? I see a number of soundbars with 3 or 4 HDMI inputs (I have 4 components that use HDMI, but can use a switch vs. having all the inputs on the soundbar if necessary, I may end up doing this anyway since due to placement of the components, ie, only have one HDMI cable running to the soundbar). Since these have hdmi inputs, can they effectively replace the receiver?
If I'm correct, do you guys/gals have any recommendations? I can easily do a 5.1 soundbar system as well since I have rear speaker mounts and cable ran already. Preferably around $500, but can go all the way up to $1000 for the right system.
Nutdotnet is offline
post #2 of 6 Old 03-31-2013, 12:25 PM - Thread Starter
Nutdotnet's Avatar
Quoted: 110 Post(s)
Liked: 41
Oh, I should also say that the room is 11x12...nearly a pefect square.
post #3 of 6 Old 04-01-2013, 01:04 PM
ahartig's Avatar
Liked: 127
I suggest a Rev 1 B&W panorama with a switcher like this:
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=5557&seq=1&format=2
HDMI out to TV, optical out to soundbar.
You can get a used one at Amazon for around $1k:
http://www.amazon.com/Bowers-Wilkins-Panorama-Integrated-System/dp/B0063C1E04/ref=sr_1_sc_2?ie=UTF8&qid=1364846610&sr=8-2-spell&keywords=panormama+bowers
and cheaper on ebay most likely.
XBOX Live ID: HONDEboyMAN
PSN ID: ahartig
ahartig is offline
post #4 of 6 Old 04-02-2013, 09:54 PM - Thread Starter
Nutdotnet's Avatar
Quoted: 110 Post(s)
Liked: 41
Ah, interesting. So that switch allows for all the components (Xbox, blu-ray, etc) to connect to it by HDMI. I can then run an HDMI cable to the tv for video and an optical cable to the soundbar for 5.1 sound. I don't need to run an optical cable from each component?
If so...that's great! It opens up many more possibilities.
post #5 of 6 Old 04-03-2013, 07:57 AM
Droid6's Avatar
If it's just the speakers that are the space limitation I would suggest you keep your receiver and go this route: http://www.avsforum.com/t/1355998/the-official-bic-america-formula-fh56-bar-owners-thread
Droid6 is offline
post #6 of 6 Old 04-04-2013, 09:11 AM - Thread Starter
Nutdotnet's Avatar
Quoted: 110 Post(s)
Liked: 41
Thanks Droid!
I actually picked up a similar solution from Klipsch on a killer deal.
Reply Soundbars
Bowers Wilkins
